foil backed insulation
Old Apr 6, 2003 | 09:55 PM
classyfish's Avatar
classyfish
Any body use the foil backed unsulation above the headliner???
Should the foil go against the metal roof, or, should the insulation go against the roof???????
thanks
Old Apr 6, 2003 | 10:44 PM
Ultramagdan's Avatar
Ultramagdan
I've never installed that type of headliner before. But foil is used to reflect heat back or to disperse heat. So it would appear to me that the foil should be on top otherwise you would be using the insulation as a heatsink or worse (reflecting heat back into the cab).
Old Apr 7, 2003 | 04:25 AM
classyfish's Avatar
classyfish
Not used as a headliner, just insulation above the headliner.
thanks for the info!!!
Old Apr 9, 2003 | 01:52 PM
beartracks's Avatar
beartracks
I just did this. Iput the foam to the top so I could use instant adesive to hold it up so it didn't cause the headliner to sag.
