All of the trailer connections are fused individually and operate off of relays. The fuses should be listed in your Owner's Manual, which you can download at the link below if you don't already have one.
fuse #38, at least on mine. I had a similar problem with mine. The stop turn signals would not work, but everything else did. I removed #6 fuse and cleaned it, and unplugged a couple of the connections near the rear bumper (small gray one and the one going into the 7 pin plug) a couple of times. Now everything is working. Sometimes corrosion plays with the connections in the back.
