Sponsored by: Real Truck
Leveling kit?
Old Sep 22, 2011 | 04:18 PM
FordGuy85's Avatar
FordGuy85
Leveling kit?
I have a 1999 F250 with the 5.4l. There is 3" more gap between the rear tires and the fender wells compared to the front. Was interested to see if anyone could give me some insight on the best leveling kit for me. I think I need a shackle lift. Was looking at the Rough country brand. Anyone have any good/ bad experiences with these?
Old Sep 22, 2011 | 04:23 PM
VONxRUBENxLA's Avatar
VONxRUBENxLA
Lift Kits, Leveling Kits, and Shock Absorbers - Suspension System Specialists! - Top Gun Customz
Old Sep 22, 2011 | 08:07 PM
FordGuy85's Avatar
FordGuy85
Thanks for the link man. I have seen this site before. I was really looking to find what kit is best. There are many different styles and brands. Just don't know what kit to go with.
Old Sep 22, 2011 | 08:11 PM
VONxRUBENxLA
Im new to all this stuff as well only have had my rig for about a month and a half I'm guessing that kits might all be similar in quality but main thing would be shock quality
Old Sep 22, 2011 | 09:10 PM
sc0r1a's Avatar
sc0r1a
I dont know anything about the shackle lifts but I bought a tough country 2.5 mini spring pack on my 01 f250 5.4 gas, so far I'm very pleased with it, didn't take long to install. It did make the truck nose high so i removed the rear stock blocks and installed new 4" blocks, which raised the truck 2 in the rear
Old Sep 22, 2011 | 09:15 PM
sc0r1a's Avatar
sc0r1a
heres a comparison of my truck
stock^ back picture and angle
Front after the "leveling" kit ^
There rear after i ditched the stock blocks and put in 4" blocks^
Looks much better IMP. Now i'm waiting on my 20" Rockstar with 33 Mud Grapplers
Old Sep 22, 2011 | 10:45 PM
FordGuy85's Avatar
FordGuy85
Hey thanks for the imput! Your setup looks awesome! Do you know what the difference in weel well measurements before you did the mini springs? I think my truck has much more height in the back than yours started with. There is an extra three inches in my suspension. I think if the mini springs raised the front end up by 2.5 then it would look perfect!
Old Sep 22, 2011 | 11:08 PM
sc0r1a's Avatar
sc0r1a
I had measurements but I lost them.
I want to say my stock was somewhere around 8.5 in the front and 11 in the rear
After the leaving kit it went to 10.5-11.5 in the front
And after I put the blocks in the rear it sits in the 13s now.
It was somewhere around there.
From factory Fords sit lower in the front. 250's have 2'' rear blocks and 350's have 3'' blocks.
And with yours being a 99 you'll have to find out if its a early or late model, couldn't tell you what the difference is, just know when you by a kit its a question that is asked.
Also I bought my lift (for my truck and Jeep) from the link above, very good company and very helpful.
Old Sep 23, 2011 | 03:11 AM
CuNmUdF250's Avatar
CuNmUdF250
Square u bolts on early superduty...u truck probaly has f350 setup in back from factory...Scor1a that looks nice will look really nice when u get u tires and wheels I'd put 35's on tho maybe its the pic but the rear still looks a lil lower to me cool truck mine is the same color
Old Sep 23, 2011 | 08:22 AM
sc0r1a's Avatar
sc0r1a
Thanks, I'm happy with it
Old Sep 23, 2011 | 01:39 PM
FordGuy85's Avatar
FordGuy85
Ok guys that info helped a lot about the u bolts. I am sure the suspension is f350 cause it has 3 leafs up front and 6 out back (not counting the overloads). So I was talking to a guy at rough country and hge said for my truck the shackled lift would be best because it won't effect ride quality. I gues if I had the extra weight of the v10 or deisel than I could run the add leaf kit. I will look into the mini springs.
Old Sep 24, 2011 | 09:39 AM
sc0r1a's Avatar
sc0r1a
Here's what the mini pack looks like installed (before I took out the stock centering pin)
Old Sep 24, 2011 | 11:12 AM
FordGuy85's Avatar
FordGuy85
That looks easy enough. Thanks for the picks! Where did you get that kit? Did it effect ride quality?
Old Sep 24, 2011 | 12:22 PM
jc8825's Avatar
jc8825
If you add a leveling kit, the front of the truck will point upwards anytime you load up the bed. This is why trucks are naturally lower in the front to compensate for weight in the rear. A properly loaded truck will sit even front to back.
Old Sep 24, 2011 | 04:26 PM
BigPigDaddy's Avatar
BigPigDaddy
I also did a mini spring pack level kit (and diesel leaf springs) then went from the factory 2" rear block to a 4" block.
Before:
After:
My truck sits level when empty, but my WD hitch levels it out when I tow the RV. My truck is almost always empty, so I prefer the level look rather than rear end high.
