That looks easy enough. Thanks for the picks! Where did you get that kit? Did it effect ride quality?
I got mine from... Lift Kits, Leveling Kits, and Shock Absorbers - Suspension System Specialists! - Top Gun Customz
It rides slightly rougher but its not bad. Not like my old Jeep.
I also ordered a lift for my jeep from the same place great company i highly recommend them.
I went back and forth weather to choose a mini leaf pack or hangers. It came down to the mini back looked safer than the hangers, just my two cents
Why would that be? If they are sturdy enough for the back ( directly under the heavy loads) then why could you not use them for the front in some states?
I always recommend my Rancho leveling kit. I'm personally not a fan of add-a-leafs or mini spring packs. When I did mine I went from 2 leafs per side to 8 leafs per side. No shackles or any other stuff. It smoothed out my ride, and helped a lot with bump steer. I also went with an adjustable trac bar from Pro Comp while I was at it. I did have to completely drop the front axle, but it wasn't a big deal with 2 people. Below are some links to old pics of stock height, and then leveled.
