Newbie Looking to Buy 1st F100....
#31
Good score. That's a damned good price for a two owner, unmolested F-100. fill the cylinders with some Marvel Mystery oil, or something like that before you try breaking it loose. Can't wait to see pics. Double check the vin though, they are sometimes easy to misread. Otherwise, there's something wrong if it starts as FLP. Post the rest of the data plate info so we can see all the details of your score. Is it a standard, or deluxe cab? With or without the side mounted spare (I like the side mounted spare the best). Going for restoration, or are you going to change it up? Something like that is restoration material, so hopefully that's the route, even it's your decision.
#32
Received 4,184 Likes
on
#37
Sorry for the dark pictures but all I had was my iphone when I looked at it yesterday. I haven't gotten it home yet, but when I do I can start a new thread with some better pics. The only rust I could find anywhere was some small holes in the running boards. I looked at the bed wood from underneath as it has a large metal plate covering the entire interior of the bed, but the wood seemed ok and a couple rotted boards.
#38
#39
As beautiful, and original as that truck is, I hope you do a resto, instead of a street rod, but that is my opinion. There are so few worthy of restorations anymore, that you have a rarety for sure. If you are wanting a street rod, I'll sell you a nearly whole 56 truck that you can chop up for dirt cheap, just to give you the opportunity to save that super clean original. And I mean CHEAP......
#40
I have every piece of the truck in a box, including the original grille teeth. He is also providing a NOS lighter, glove box ****, front V8 symbol, and a few other little parts. My plan is to keep everything original other than the stance of the truck. I want to put some lowering springs on it to give it a more street rod stance. But other than that I am going to sand and strip it and paint it with a black epoxy primer for now. I am hoping the original drive train is useable, that way I can just rebuild the motor and trans if need be and drive it. That way it is kept as original as possible for the time being and later down the road I can always go with a full restore. I don't plan on ever getting rid of this truck, so I have plenty of time to enjoy it.
#41
#43
Ok so i would feel bad if i started chopping it up and modifying it... But i also want a truck i can safely drive down the highway and feel safe in on weekends. Am i going to get crucified by folks if i take some leafs out or get new mono leafs to lower it and change out the rearend with a newer ford 8.8 and some front discs? I dont want to chop it or c notch the frame or anything extreme, but i do want a safe highway driver.
#44
#45
