Chip or Programmer or?
Old Sep 22, 2011 | 02:58 AM
Seaswirl77's Avatar
Seaswirl77
Have a 2006 F350 Super Duty 4X4 Dually and looking for a chip or programmer or ?....to improve gas milage ans assist with my camper on board - suggestions?
Old Sep 22, 2011 | 03:59 AM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
Gas or PSD?
do you tow with it? heavy hauling (near max GVR)?
Old Sep 22, 2011 | 07:22 AM
BPofMD's Avatar
BPofMD
Veteran: Navy
Your truck doesn't take a "chip", but a tuner. If you haven't installed ARP studs, don't do it. If you have, most here go with the SCT X3 with custom tunes.
Old Sep 22, 2011 | 10:57 AM
Seaswirl77's Avatar
Seaswirl77
I mostly haul a 10 foot Biggfoot camper and that is it. Oh by the way - I have a 6 litre diesel........so the SCT X3 is tghe way to go?
Old Sep 22, 2011 | 12:45 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
AGAIN, ONLY if you have ARP headstuds installed......
Old Sep 22, 2011 | 05:11 PM
2006powerstroke90's Avatar
2006powerstroke90
I agree with the ARP headstuds.
Dont tune it without them.
Old Sep 23, 2011 | 10:56 AM
jdadamsjr's Avatar
jdadamsjr
Yes, but any custom programmable sct will work.... I have the older sct I got way back when and it will load the latest tunes...
Old Sep 23, 2011 | 03:17 PM
tex25025's Avatar
tex25025
Not necessarily true. While increasing HP/TQ does increase one's chances for "issues" with the heads, the mere fact of having a tuner on there doesn't make it the case.
A lot of it, in my humble opinion, has to do with how a tuner(device) makes it's power out of the truck and that has the biggest direct result on if you will have issues out of the heads or not. Custom tunes lowers those odds. I'm not saying that they aren't there, but not as high if they go with a reputable tune writer.
However, the OP does have to proceed at his own risk.
Old Sep 23, 2011 | 03:19 PM
2006powerstroke90
Agreed......
Old Sep 23, 2011 | 03:32 PM
tex25025's Avatar
tex25025
I forgot to add, please don't do this with a mind toward MPG improvement. These are performance enhancement products first and foremost. Don't fall into the huffing that the companies due in their ads. Read the small print if in doubt. I saw a lot of "results not typical", "our customers noticed..." etc, when they really try to sell the MPG improvement aspects.
Old Sep 23, 2011 | 04:11 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
Would YOU advise anyone to tune their Ford with a 6.0 engine to install a tuner that DIDN'T have studs???
Old Sep 23, 2011 | 04:31 PM
tex25025's Avatar
tex25025
It depends on what tuning there were going to do with their truck and if it was custom or off the shelf.
Having a tuner on your truck doesn't mean in of itself you will pop bolts. Not doing anything doesn't mean you won't pop bolts either.
Old Sep 23, 2011 | 08:02 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
yep. in a heartbeat. As with everything, if you want to play, you have to pay.
So if you do tune, be aware you could have issues.
I am going to run Gearheads SRL tune on my unstudded 6.0...however I am going to ask him to detune it a bit. I want more performance, but honestly just a little less turbo lag and I'd be 1 happy customer. This truck will spin my 35" tires easily once boosted. Just getting into the boost takes a little effort off the line
Old Sep 24, 2011 | 07:59 AM
tex25025's Avatar
tex25025
Either start boosting while you're stopped or roll into it. In all honesty, rolling into is actually better in my opinion.
I know when I roll into the boost on my truck it is pretty damn quick, but having pretty low gears helps as well. However, I must say that the peak boost I've seen on my turbo is 52PSI.
Old Sep 25, 2011 | 01:39 PM
Tylus's Avatar
Tylus
MMNC (SS)(Ret)
Veteran: Navy
I figured out the roll-in on the throttle a few weeks back. Then read about it somewhere on here. Thought there was something wrong...then thought about it and the VGT stuff
