Help Needed and some crying.
A lot of guys seem to prefer autos in Gassers, Manuals in the diesels. While autos are becoming more popular, there will always be manual transmissions in the heavy duty work and towing industry.
Also check the power cable at the starter. If that nut comes loose the cable can rotate and ground itself.
Also, check the switched side of your glow plug and AIH solenoids (assuming 99.5 model or later and you don't have the GPCM). If either solenoid sticks, it will drain your batteries quickly.
