92 f150 4x4 electrical problem
Old Nov 18, 2002 | 07:42 PM
lombardy's Avatar
lombardy
Post 92 f150 4x4 electrical problem
My truck shows low voltage on the dash gauge while the altenater shows an output of 14.6 at the battery and the fuse box under the hood. after driving for 45 minutes or so the gauge starts to climb to amore normal position and the accessories function much better, including engine performance.any sugestions as to whats wrong.thanksfor any help.
Old Nov 18, 2002 | 08:54 PM
Mil1ion's Avatar
Mil1ion
Do you have a Volt-meter or do you actually have an Ammeter?
Ford's gauges are notorious for not working properly.
The best way to tell is to use a Multi-meter to know for sure what is
going on.
Dennis
F.T.E. Assistant Administrator
[link:www.ford-trucks.com/guidelines.html|Club FTE]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
Old Nov 18, 2002 | 09:43 PM
steve83's Avatar
steve83
Check the battery terminals, the ground wire terminals, and all the ring terminals at your starter relay on the fender near the battery. They should be clean & tight. Use a fine-bristle wire brush to polish them, and lube them with anti-sieze compound. Also, check the terminal on the side of the engine-compartment fuse block.
Old Nov 21, 2002 | 05:29 AM
lombardy's Avatar
lombardy
yES IT IS A VOLTMETER AND EVERY TERMINAL THAT i CAN FIND BOTH POWER AND GROUND ARE CLEAN AND TIGHT. i HAVE A HAYNES MANUEL BUT SOME OF THE WIRING DIAGRAMS ARE NOT DETAILED OR ARE INCORRECT FOR THE VOLTMETER AND IGNITION SWITCH WIRING. iF YOU HAVE ANY IDEAS LET ME KNOW. THANKS.
Old Nov 21, 2002 | 11:37 AM
mrwizard's Avatar
mrwizard
