ok my fellow flathead freaks ........
Old 09-22-2011, 08:03 PM
55 f350's Avatar
55 f350
55 f350 is offline
can one of you tell me if the isky and speedway adjustable lifters are hollow or solid ????? gonna order some parts me hopes soon and they are on the list . kinda leaning towards the flatattack hollow ones red's carries but still weighing the options . also any of you guys tell me does the factory 8cm cam got a lope to it or smooth idle ?? either way it's going in but kinda curious ........
Old 09-22-2011, 08:18 PM
ALBUQ F-1's Avatar
ALBUQ F-1
ALBUQ F-1 is online now
AFAIK the only ones that are hollow are the Flatattack ones, and some of the old Johnsons.
If you are using the 8CM cam, why use adjustables? Henry's production lifters are the lightest of all of them, extremely durable, and no worries about going out of adjustment for tens of thousands of miles. If your engine is apart, it's not "that" much more work to get the proper clearances with stock lifters. Adjustables are needed on reground cams and some hi-lift new cams, but an 8CM is a stock cam.
Old 09-22-2011, 09:29 PM
55 f350's Avatar
55 f350
55 f350 is offline
no access to a valve grinder ross . and i'm about as proficient as a cub bearing playing with itself with boxing gloves on with finite things like that . i know the oe ones are the best but due to circumstances i was onto plan b ...................
Old 09-22-2011, 09:31 PM
55 f350's Avatar
55 f350
55 f350 is offline
oh and outside of dave brown i dont trust anyone around here with a machine shop . i've seen some of the " fine " work they do . dave is fighting cancer so it may be tomorrow they're done or 6 months from now after i give him the measurements and the new valves .{ bud had a valve grinder but it's kinda broken now thanks to one of his grand kids playing with it }
Old 09-23-2011, 06:18 PM
38 coupe's Avatar
38 coupe
38 coupe is offline
The 8CM cam is a smooth idle.
55 f350
Flathead V8 & Flathead 6
08-12-2012 11:13 PM
mpc07005
07-17-2012 09:09 PM
austynn2001
08-27-2006 12:43 AM
ScottJM
02-16-2005 11:52 PM
0270
10-09-2004 12:25 PM
Quick Reply: ok my fellow flathead freaks ........
