Front fenders for 53-56 Ford big truck. F500, etc.
Category: Accessories
Price: $300
Private or Vendor Listing: Private Listing
Part fits (you may select multiples): CRX & pre '92 Civic
Item Condition: CA
there's a little bit of rust in the dark spot between the bolt holes. And below, where the dark oval is, there's what appears to be a weld, and maybe some high-heat shrinks for body work? The opposite side is where the filler patch was peeled out in the last pic. From the inside, it looks pretty good though. The red is all the original body paint.
I will get pics of the inside of the driver's fender Tuesday. It's still assembled to the inner right now.
The driver's side fender is nearly mint minus a small ding above the headlight. No rust on the driver's side. A little rust where the pass. fender meets the running board between the bolt holes.
are these BIG JOB fenders or standard f500 (narrow) style?
They are not Big Job fenders; (F700 and up). But F500 are still noticeably wider than F100, etc
I am interested in your f500 fenders are they still available?
That's great! I would like to make arrangements to buy them. Do you have any other f500 parts for Sal???
I also have the running boards, and an auxiliary transmission... aka Brownie box with driveshafts and shifter.
I might be able to use the running boards but I was really looking for the grill.
The grill is the same among all the truck sizes. The only exception would be the special bread truck vans
Whats your offer?
My budget is $150 I might be able to do a little more but I can't do $300...
Are you planning on picking them up or shipping?
You happen to have a nice drivers side F100 fender or other goodies to trade?
I could do $250 for the pair.
