Power Steering Fluid??
Old Apr 6, 2003 | 03:29 PM
Steve Shulz's Avatar
Steve Shulz
No book or spec for new truck. Power steering fluid is low, appears to be break fluid, am I safe to assume thats what is used for this pump. 87 6.9l Diesel
Old Apr 6, 2003 | 03:35 PM
MustangGT221's Avatar
MustangGT221
It's powersteering fluid.
Old Apr 6, 2003 | 08:01 PM
Racerguy's Avatar
Racerguy
Hi Steve Shulz and welcome to FTE
Like MustangGT221 said it is probably actual power steering fluid but you can also use ATF with no problems. Don't use brake fluid in it.
Old Apr 6, 2003 | 08:55 PM
mike460's Avatar
mike460
actually use power steering fluid. ive read an article or two saying that if the manufacturer doesnt specifically state to use atf use power steering fluid. something about viscosity and detergents. just go to the parts store and get anything labeled power steering fluid(but not with the word honda in front...thats for hondas...heh). oh, and if it leaks like mine does....throw and extra quart under the hood over near the master cylinder....easy to reach and youll always have some with you wherever you are.
mike
Old Apr 6, 2003 | 09:30 PM
AggiePSD's Avatar
AggiePSD
This topic came up before, and most of these trucks, or at least the ones i have worked on, specify it is ok to run Type F transmission fluid in the power steering. I have seen it in the owners manual, but check yours specifically.
Old Apr 6, 2003 | 10:59 PM
Racerguy's Avatar
Racerguy
On the newer trucks Ford actually specifies Mercon ATF.
