Hi everyone new to this forum. I have a 2007 F350 and am fixing to sell it. Don't need anything that big. I am going to buy a 1993 to 1996 Supercab F150. I have found several with great miles and excellent shape. My question is 302 or 351. I previously owned a 1993 with the 302 but I have found several with 351 and wanted to know the pro's and con's of each. The only pulling I would be doing would be a travel trailer around 6000 pounds.
The mileage is almost the same for both engines, the 351 works at a more relaxed pace, both engines will last A LOT with proper maintenance, if it where my choice, i would prefer the 351, also, whatever you choose, try to get the MAF version, it will be more apt for modification further down the road.
I'd get a 351. I'm actually planning to swap mine. The 302 is a great motor. I have 290,000 miles on mine and its never even had a valve cover off. I still perfer the low end power of a 351 though.
if you were looking for a 250, I'd say get the 351. Since the 150 is a lighter truck, I think the 302 would do you well. The 302 is easy to modify, and repair parts are generally inexpensive.
Im a huge fan of the 302 as well. I use my 1/2 ton truck as a light duty truck so Im not in need of big power (I have a diesel for the real work truck). Ive yet to see a 351 come anywhere near the fuel economy of a 302 as well.
My 89 f150 has a 3.08 rear end, its a 4x2 witha m5od and a 302, and when i drove the truck as my daily driver it got 20-23 mpg when I drove it decent.
For my needs in a 1/2 ton truck, ya just cant beat the 302.
