4wd will not engage
Old Apr 6, 2003 | 09:40 AM
2lane's Avatar
2lane
4wd will not engage
2001 sport trac. When I turn the **** to engage either 4wd high or low all I get is a hum from the solenoid on the transfer case. Neither light, 4wd high or 4wd low, on the instrument panal lights up. Any ideas on the problem. Every ones in a while the 4wd will ingage but when you turn it off and right back on you may have the same problem.
Old Apr 6, 2003 | 08:08 PM
davidm's Avatar
davidm
4wd will not engage
I have a 93 Ranger that does the same thing every now and then. All I do to fix it is tap the shift motor on the transfer case with a rubber mallet a few times, not too hard but not softly either. I seem to only have this problem when I go a while without using 4 wheel drive. I try to use it at least a few minutes a week just to keep things moving. I think my shift motor just gets frozen up. Using the mallet has worked every time. If it doesn't work for you, use a test light and see if you have power at the shift motor. If you do, you may have to replace it. That's my thoughts. Hope this will help.
Old Apr 8, 2003 | 06:32 PM
2lane's Avatar
2lane
4wd will not engage
I found the problem with my Sport Trac. The electric shift motor on the back of the transfer case is sticking and a new motor is about $270-just for the motor no labor. Thanks for the reply.
tonythepony
1997 - 2003 F150
Nov 25, 2014 09:46 PM
packerfan2323
2004 - 2008 F150
Nov 5, 2014 03:11 PM
4x4greenbeast
17
May 22, 2014 12:10 PM
mlm1013
2004 - 2008 F150
Feb 20, 2014 02:56 PM
don96exp
Mar 3, 2005 10:55 PM
