Front end wobble
Old Sep 17, 2011 | 01:16 PM
JonArmy's Avatar
JonArmy
Front end wobble
I have spoken with Tire Kingdom pretaining to my 04 F350 SD 4x4. At times when I am running around 38 to 45 I get a front end wobble. They are going to do a check next week since there schedule is booked for awhile. I spoke with the head FMC service department head who knows me and the family and helps me out, he says it might be a bent rim, I'll have to find out what it is since I have CarMax warrenty. Whatis everyones idea on the wobble.
I'm getting my coolent drained/flushed/simple green/vc-9 then final flush and refill at the end of the month (since I bought this truck used and of course don't know what the previous owner has done).
When i'll do my next oil change and I also chaning the rail and engine fuel filter/ drain the water seperator put the upgraded HFCM plug on and also put a coolent filter on to help get gunk out of the coolent.
I have read about a updated flash for the SD, when I talked with the tech he didn't know to much about it and he told me if I can show him the information on it he will check to see if I need it and all.
Old Sep 17, 2011 | 05:09 PM
BLADE35's Avatar
BLADE35
how many miles???
check balljoints
and the front axel steering knuckle ujoints and drag link/pitman arm
any odd tire wear
any odd impact marks on the rims
Old Sep 17, 2011 | 05:19 PM
JonArmy's Avatar
JonArmy
40k, I have looked at the balljoints and they look fine. I have found only 4 grease points and have added some grease to them, all the other grease points are non-servicable points.
Tires look good, they seem to be wearing good, I have looked at the rims and they look fine, but speaking with the FMC tech the tires look good and all, I'll get them rebalanced and rotated just to be sure.
I have had the truck in the shop a week after I got it with 38k miles on it, the alignment was good, but the steering wheel was off center which got corrected.
When I get TireKingdom to do the free check I'll be able to confirm some of those same items, since I don't have a lift and and full supply of items to check everything.
Old Sep 17, 2011 | 05:49 PM
BLADE35's Avatar
BLADE35
Front axel u joints are easy to check
turn steering wheel full left truck needs to be in 2wd get out and spin the axel each side by hand right at the u-joint
Both should turn freely with no slop at u joint
turn truck to right and repeat
and one more time tires pointed straight ahead
Ball joints alittle harder to check I couldnt tell on mine till I took the tires off but usualy have odd tire wear cupping ect...
If they find a bad ujoint or ball joint make shure they put greasable ones on I beleive that they sell a greasable motocraft one now
Im happey with the Moog stuff iv put on I hear spicer is pretty good to
Primetime1
Sep 17, 2018 08:48 AM
Muddy Creek
15
Nov 13, 2015 03:35 PM
kbf1961
Oct 7, 2014 04:09 PM
MADFord4X4
13
Jul 12, 2010 08:50 AM
dornauer
Jul 15, 2004 05:53 PM
