Chip for my EX
Old Sep 16, 2011 | 09:35 AM
thebigsmooth's Avatar
thebigsmooth
Chip for my EX
Sorry for my ignorance but how can I tell if an EX has a chip on it or not?
Old Sep 16, 2011 | 03:17 PM
aklim's Avatar
aklim
Chip as in what? Look at the PCM and see if there is anything hanging out of it.
https://dp-tuner.com/skin/frontend/d...stallation.pdf
See how the install instructions goes as far as helping you.
To see if there is a program on it, you might need to bring it to a Ford garage that can interrogate the PCM.
Old Sep 17, 2011 | 07:32 PM
ke6zmy's Avatar
ke6zmy
I do not see if your Ex is a diesel or gas, or what year it is, but I would guess they are all pretty much the same when it comes to the chip location.
My T&S chip comes out of the rear of the computer. PCM? ECM? I do not know the acronym. However... The chip sticks out of this box. The box is perpendicular to the firewall behind the E brake on the left.
If there is a rubber gasket, or if the rubber gasket is missing because the previous owner removed the chip and failed to re-install the rubber gasket, you have no chip.
My T&S chip simply slid over a location on the circuit board after the lacquer coating was sanded off. When installed it protrudes out of the box.
The chip has a wire that goes to a dash mounted dial switch. I rotate the dial clockwise to increase the power, and/or other adjustments, or counterclockwise to do the opposite. 1st pos. is stock setting. 2nd is stock w/ a high idle. 3rd is an additional 50 hp or so. 4th is more hp. and so on. It has been a long time since I used more than the 1st 3 settings but I believe it is a 6 pos. chip. Final total hp on my '03 7.3L Ex??? 425 or 450 hp.
robinsonpowerstroke
Ford Truck Parts for Sale
Oct 22, 2009 11:02 AM
dirty diesel 07
Feb 27, 2008 06:09 PM
raptor05
May 17, 2006 09:36 PM
RustyWallace
Computer Chips & Tuners
Nov 16, 2003 11:24 AM
Trail Rider II
Sep 14, 2003 10:55 AM
