The Ultimate Super Duty Picture Thread.
With those two lightbars, I am surprised you can even tell you have headlights...
Why not do what Micah did and switch your headlights to these:
You just need a test light or volt meter so you can tell which wire is high beam and which one is low beam.
If you can get a hold of the header panel its even easier.
I know it can be done on an xl, but honestly I really don't care if they are power or not. Hence why I bought an xl, less things to go out, or break.
And I know the general electric nighthawks are expensive but they are worth every penny. Super bright and way too easy to install lol.
They have a great light pattern, and if you buy them on amazon as a pair you get $100 off. At least I did, there was a coupon to click to save $100.
Anyways, have no concerns about putting the 05s on like Micah said. RiffRaff Diesel has a really nice document to aid in installation. Check it out:
http://www.riffraffdiesel.com/conten...structions.pdf
They also sell conversion harnesses: 9007/9008/H13 Conversion Harness Pigtail Set for Ford 7.3L 99-04
Here is my post from when I put them on my truck. Hopefully the pictures help: https://www.ford-trucks.com/forums/1...l#post14574586
I didn't realize that was per bulb. I thought it was the pair....
I have their write up, but like i mentioned before, everything is written up but no one ever mentions sealed beam set ups. But great pictures and info!!!!!!!
Take a look at the LMC truck catalog for Super Duty. The have really nice exploded views of stuff with parts numbers you can reference. That should help solve your problem.
Truck Parts and Truck Accessories
Okay well hopefully i dont have to adjust them, because on the sealed beams, thatll end up being cut out once i do this. So ill loose all adjust ability on these. But ......... screw it! Ive committed to doing it this weekend.
