Here's a couple shot's right after i put Bumper's on & i only had 1 set of Piaa's but i just got the 2nd set installed the other day.
I will be uploading better pic's when possible, thanks everyone for the kind words
I noticed that your right tail light sits close to the tailgate like mine did! I found out a trick that i just never thought of when i installed them. The two tabs that snap in to hold the light to the bed before the screws go in can unscrew, if you unscrew the top one i think i did about 3 or 4 turns it sits like the stock tail light and not against the paint on the bed. I noticed that my paint bubbled because the tail light was rubbing it and the paint was fairly new so i went by to see my auto body guy and he mentioned to try that and it worked beautifully, cant believe i didnt think of that before. Its a 10mm deep socket btw.
cant hurt! I'm pissed mine bubbled especially since i got the whole truck painted last summer .. Oh well ill put some paint in the bubble to keep it from spreading i guess.
I just adjusted it & your trick works....Rep's given
While i was outside being picky, i also moved the left side a smidge & i did have a very small amount of rubbing that i couldnt see from outside, but a little touch-up paint fixed that....Thanks again
No Problem it always bugged me too and then I discovered that trick recently and thought about all the people running these lights that just leave them like i did lol.
Patchy, people must wonder when they see that snorkel there huh, how deep have you had it........Grimshaw looks happy to be there, nice clean truck, welcome to FTE
Only to the top of the tires
Need to know your limits,Any deeper you could be in problems
And for Miss Grimshaw it's her back seat
Cheers,
Patchy
Reason: a few to many JD's
Nice Patchy & welcome to FTE
I must say ive never seen a SD w/a Snorkel
I also noticed your "sealed beam" headlamps have a custom cover so they almost appear to be "composite".....Neat upgrade
Ive also never seen a Bumper that Big in chrome, thanks for posting
