Roller cam vs. flat tappet vs.$
Old Apr 5, 2003 | 09:17 PM
badassfordpu's Avatar
badassfordpu
Okay i know the that the roller cam reduces friction and can open
the vavlesquickerand stuff but.... lets say I had an identical cam
with the same specs, how much of a differernce would there be?
Horsepower.
torque.
gas mileage.
I want to hear some examples. "if possible"
Old Apr 9, 2003 | 02:03 PM
teschwab's Avatar
teschwab
i can't answer that question with the info given. i would say that the roller cam has made the 302/5.0 more potent down low as far as torque is concerned. you mentioned the fact that the roller lifter allows for a more radical lobe ramp and opens and closes the valve with a lot of efficiency when compared to the traditional flat tappett. i subscribe to the theory that valve component weight contributes to an engines ability to rev and its durability at elevated rpm. so the best answer in my opinion is that the roller cam will operate more effectively at lower rpm than the flat tappett and will be more crisp in regards to low end throttle response. if it boils down to dollars and you are considering a reduced base circle cam for a early model retro. i would stick with the flat tappett. if i had a roller engine i would not replace the roller cam with a flat tappett cam.
Old Apr 9, 2003 | 03:08 PM
big1's Avatar
big1
You said both cam's had the same spec's correct? If so the only power gain's would be realized in friction reduction.
Old Apr 9, 2003 | 03:43 PM
Ratsmoker's Avatar
Ratsmoker
Friction reduction is much less of a benefit than being able to run a much more aggressive lobe design. It would be a waste. Very little increase in power.
Old Apr 9, 2003 | 07:41 PM
StrangeRanger's Avatar
StrangeRanger
The whole point of a roller is to allow the much more agressive ramp angles which in turn allow greater dwell without increasing overlap. If you're not going to get the benefits of a roller, why would you want the added complexity?
Old Apr 10, 2003 | 11:38 AM
badassfordpu
Very good feedback I guess I will be staying with the same type of cam thanks just a bigger lift!
