not running right...
Old Sep 14, 2011 | 01:59 PM
achtungeveryone's Avatar
achtungeveryone
ok, the engine (5.0) starts but is sluggish when cold and has low,low idle. when warm it wants to rev high so i hit the accel and it falls down to a nice range but once i'm accelerating again and let off gas it wants to rev high.
also, and possibly related is that there is some sort of heater tube from man. to carb (2v) that is broken above the manifold connection. what is this called, is it important and if so what is a good online that may have.
thanks for any help, advice.
chris
Old Sep 14, 2011 | 03:01 PM
JAYS69F100's Avatar
JAYS69F100
Sounds like a vacuum leak, very well could be the line going from the carb to manifold. Is it automatic? if so check the vacuum line to the modulator valve on the tranny, sometimes comes lose. Check the timing, replace the said line and recheck timing.
Old Sep 14, 2011 | 03:26 PM
tmcalavy's Avatar
tmcalavy
Check all your vacuum connections, around the intake manifold and carburetor. Also check the cold idle/fast idle setting on your carb. Sounds like that may be sticking...the high idle you mention. Check that the carb is down tight. Also check base timing and dwell/points/condensor. You're missing the heat riser tube that is supposed to help it (carb) warm up quicker. No loss...if you really want/need one, check your local junkyards for old bump trucks.
Old Sep 14, 2011 | 03:49 PM
achtungeveryone
thanks for the reply, i'll check those things you mentioned.
Josh.indorf
13
Feb 23, 2020 11:37 PM
CaptnNoodld
Apr 26, 2012 05:34 AM
drmgoat
18
Nov 11, 2008 10:35 AM
BuffDaddy
Jun 25, 2006 11:06 AM
MonsterBroncoKid
1978 - 1996 Big Bronco
Nov 30, 2004 07:16 PM
