Fender/cab question
Old Sep 14, 2011 | 01:25 PM
chicken1's Avatar
chicken1
Fender/cab question
Hi all,
I was wondering if the cab and the bed off of a 1973 Ford f100 would fit on a 1978 ford f250 frame?? The f100 does not come with fenders or any of the rest of the front end, would the fenders, grille and whatever else that were on the 78 fit onto the f100 cab and bed? Thank you for all your help and have a great day!!!
Old Sep 14, 2011 | 03:46 PM
john81chevy's Avatar
john81chevy
Yes, the cab, fenders and bed should all interchange. I am assuming the F100 is also a longbed.
Old Sep 14, 2011 | 07:15 PM
chicken1's Avatar
chicken1
Thank You you for your help. And yes the bed is a longbed, my mistake I forgot to put that in the question, sorry. Thank you for your help!! Have a great day!
Old Sep 14, 2011 | 09:49 PM
79 shortbed lover's Avatar
79 shortbed lover
I think the frame is narrower on the 73 than the 78 you may have to drill the mounting holes but no big deal.
Old Sep 14, 2011 | 11:43 PM
chicken1's Avatar
chicken1
Ok, Thank You Shortbed for your thoughts! I will sit down one of these days and figure out what I have to do
Old Sep 15, 2011 | 01:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
1973 F100 & 1978 F250: The rear frame rails are the same width:
33 1/2" width between the inner rear frame rails: 1973/77 F250 4WD (High Boys) / 1973/79 F350 Regular Cabs on the 140" wheelbase.
37 1/2" width between the inner rear frame rails: 1973/79 F100/350 except as noted above.
Stylesides: 1973/76's have exposed fuel caps / 1977/79's have fuel doors.
Not only are the left quarter panels (bedsides) different 1973/76 vs 1977/79, but so are the fuel filler tubes and fuel filler hoses.
And, if the truck has the Evaporative Emission system, the fuel cap(s) are non vented and the filler tube(s) are specific to non vented fuel cap(s).
Old Sep 15, 2011 | 01:54 AM
Skip1970's Avatar
Skip1970
are them measurements to the inside of the frame or outside?
Old Sep 15, 2011 | 02:06 AM
NumberDummy
The width between the inner frame rails (behind the cab) is either 33 1/2" or 37 1/2"
Since you have a High Boy, the frame rails on your truck are 33 1/2."
This rear frame rail width jazz also applies to rear bumpers and brackets.
wrongwaypeachfuzz
Sep 2, 2018 10:20 AM
black63
Aug 13, 2007 08:18 PM
53pickemuptruck
Apr 22, 2007 05:30 PM
houghda
Apr 10, 2007 07:49 PM
63SCtruck
Feb 29, 2000 12:13 PM
