rotor resurfacing?
Old Sep 13, 2011 | 11:07 AM
earlybirds's Avatar
earlybirds
rotor resurfacing?
I put powerslot cryo rotors on all 4 corners of my 1999 Explorer a couple years ago so that they would last a long time. Recently I have noticed a very slight back & forth shimmy in the steering wheel when applying the brakes at low speed. It is barely noticeable, but it is there.
My question is, can I get this type of rotor resurfaced if they are indeed slightly warped? I am not hard on the brakes when applying them. The vehicle has mostly highway miles.
Old Sep 13, 2011 | 10:55 PM
whitefordexplorer's Avatar
whitefordexplorer
if your rotors arent drilled or slotted, they can be re-surfaced. double check with the manufacturer to be sure.
Old Sep 13, 2011 | 11:05 PM
aquanaut20's Avatar
aquanaut20
A warped rotor normally exhibits via pulsing pedal, what you describe would direct me to check for tread separation on a front tire... Philip
Adirondacker
Jun 14, 2010 03:53 PM
herman391
1983 - 2012 Ranger & B-Series
Nov 19, 2008 04:27 PM
berry1234
13
Feb 7, 2008 10:42 AM
ISHERWOOD
Jun 29, 2004 01:58 PM
krane operator
Sep 23, 2003 10:38 AM
