EVAP error code question...
Old Apr 5, 2003 | 02:09 PM
Pioneer Ford's Avatar
Pioneer Ford
Question EVAP error code question...
My check engine light came on due to a "P0442 EECS gross leak detected" code. My question is, where is the system? Where is the purge solenoid? Where are the lines? I can't even find the charcoal canister to check for leaks. Where is it all? When I find it, is there a common area for leaks? I've heard the gas cap can cause these codes, but it looks fine. Is this a common problem with rangers? Any advice? Thanks
Old Apr 5, 2003 | 09:30 PM
Ken00's Avatar
Ken00
I beleive you will find it up under the bed.
Old Apr 6, 2003 | 01:25 AM
Jofrso's Avatar
Jofrso
What year is your truck? I had the pruge sensor go on my 95 ranger. All the lines and selenoid sensor and canister are in the engine compartment, drivers side at the front corner. The canister is in the area underneath the battery, just follow the lines back from the canister toward the engine and you see the inline selenoid and the inline sensor. The problem could be the canister, selenoid or the sensor that could be the problem. Maybe one of the lines are disconnected or damaged.
Old Apr 6, 2003 | 01:52 PM
Pioneer Ford
It's a '99 w/ 3.0 FFV. I looked under the hood but had no luck. I might have found the purge solenoid but I'mnot sure. If it's near the gas tank, would it be on top, wher I can't see it?
