Stock rim width
Old Sep 12, 2011 | 12:21 PM
billt28's Avatar
billt28
Stock rim width
What is the stock rim width for an 86 F-150 4WD?
Old Sep 12, 2011 | 01:04 PM
LARIAT 85's Avatar
LARIAT 85
If you have the stock 1986 silver steel wheels (wagon wheels), the size is 15 x 7".
7" was the widest wheel offered during these years.
Old Sep 12, 2011 | 01:11 PM
billt28's Avatar
billt28
Thanks Lariat.
Old Sep 12, 2011 | 01:17 PM
LARIAT 85's Avatar
LARIAT 85
You're welcome. In 1987 - 1991, Ford offered the same silver style "wagon wheels" in a 15 x 8" size that came on Broncos and possibly the 4wd F-Series trucks as well.
Old Sep 12, 2011 | 07:18 PM
Franklin2's Avatar
Franklin2
Most stock issue rims that take some sort of wheel cover are 6 inches wide. Those other wheels were optional.
Old Sep 12, 2011 | 08:51 PM
billt28's Avatar
billt28
I found a set of what i believe to be stock rims with a chrome ring in the junk yard i was thinking about buying. I want to get rid of the 31's i have on my truck right now and go back to stock size.
Old Sep 12, 2011 | 09:36 PM
LARIAT 85's Avatar
LARIAT 85
If they have chrome "beauty rings", they must be the deluxe "wagon wheels" Ford used from 1982 - 1991. As I said before, they can be either 15 x 7" or 15 x 8", depending on what they came off of.
Do they look like this?
Old Sep 12, 2011 | 10:09 PM
Gary Lewis's Avatar
Gary Lewis
So, the 15 x 8 white wagon wheels that I got on the '82 donor are later issue? They are stamped Ford, so were stock for something. Thanks for the info.
Old Sep 12, 2011 | 10:16 PM
LARIAT 85's Avatar
LARIAT 85
I have never seen nor heard of white Ford wagon wheels in the 15 x 8" size.
However, the white wagon wheels that Ford did offer were 15 x 7". If you sure they are 15 x 8", I suppose it is possible that someone got a set of the later 8" wide wheels and painted them white.
Old Sep 12, 2011 | 10:36 PM
Gary Lewis's Avatar
Gary Lewis
Well, they have certainly been rattle-can painted, so it is quite possible they weren't white to start with. They would have been silver new?
I'll have to pull one, again, and make sure I know what I'm talking about, but I'm pretty sure they say Ford and 15 x 8. On the other hand, it wouldn't be the first time I was wrong - today. But, I know that another FTE'er and I looked them over and remarked that they were 8's.
Old Sep 13, 2011 | 01:05 PM
81-F-150-Explorer's Avatar
81-F-150-Explorer
Stock wheel sizes for the F-150/U-150 and E-150, during this time frame (80/86).
1) 15x5.5
2) 15x6
3) 15x7
Most comon factory tire sizes in todays metric measure: P215/75R/15(XL or SL) or P235/75R/15(XL or SL).
There were some SAE measure tire sizes avaliable, but not sure what good it would do to post them.
Old Sep 13, 2011 | 03:40 PM
lavatan's Avatar
lavatan
This is sort of on-topic. What are the stock size on the 1985 F-350 2wd Crew Cab? The tires that are on there now don't have the normal identifying tags. The fronts have 6 lugs and the rear has 8 if that helps. Thanks in advance.
Old Sep 13, 2011 | 05:41 PM
billt28's Avatar
billt28
Yes. Those are exactly like the ones I've been looking at (minus the tires of course LOL). I think they would go perfectly with the color of my truck.
Old Sep 13, 2011 | 06:33 PM
Franklin2's Avatar
Franklin2
That doesn't help at all. Did Ford even have a 6 bolt pattern? I am thinking not.
Old Sep 13, 2011 | 06:55 PM
LARIAT 85's Avatar
LARIAT 85
I think they would go perfectly with the color of your truck too, billt. Ford called those wheels Deluxe Argent Styled Steel Wheels and those were the best wheels (highest option) offered from 1982 - 1986.
If you want to be correct, the Bullnose years ('80-'86) had the black/red center medallion wheel centers and the red rally stripes in the wheel rings, just like the picture I posted. Later versions after 1989 used a solid black center medallion and dropped the red stripes in the wheel rings.
