What carb to buy??
Originally Posted by MiddleNameMUD
Wow GREAT answers!! Drainbramage that was probably the most decicive and informative answers I have have ever asked for! Reps for sure!
The autolite with the hot air choke, isn't the hot air supplied off the intake? If I remember right there isn't any connection on the intake I bought. Would I be able to purchase this carb with a manual choke? The reason I say this is my stock 2bbl works great, I'm just up for improvement. Thanks again guys!
Neither the Autolite 4100 nor the Motorcraft 2100/2150 came with a manual choke. These carburetors came with an automatic hot air choke that sourced the hot air from a chamber in the passenger's side exhaust manifold. The fresh air tube sourced clean, filtered air from the carburetor air horn and routed it to the choke stove chamber located on the exhaust manifold. The air gets heated in this chamber and routes back up through the insulated hot air tube where it connects to the choke cap, and controls the choke operation in direct relation to how hot the engine is. That is what makes these chokes superior to the all-electric chokes found on all aftermarket carburetors that rely on a timer.
Originally Posted by DrainBramage
With my truck, now that I have headers and an aftermarket intake, I plan on running a coil of steel tube around one of the primaries and then up into the bottom of the choke. The other end of the tube will get hooked into the nipple on the carb that goes directly into the air cleaner. This will make sure I don't have unfiltered air coming into the other side of the tube and then into the choke. It should work OK but will probably take some fiddling to get it adjusted correctly.
hey 85 mabe you should learn how to read and who died and made you the grammer king any ways? i got my point accross and thats all that matters are we in a truck forum or school? to each their own and i still say if those carbs were any good they would still be on my trucks and not in the garbage as all my trucks came with the original carbs and they all leaked from sitting
If you are looking for a pi$$ing match, keep after him, otherwise ignore him.
Credit where credit is due, he is actually supporting his opinion with some facts in this thread.
whatever .... I guess I'm cranky this morning ...
That being said, if you think the stock Motorcraft carburetor belongs "in the garbage," then you are giving terrible advice because you don't know what you're talking about. Its common knowledge that the Autolite/Motorcraft 2100/2150/4100 carburetors are some of the BEST carburetors ever made. Every single carburetor made is going to leak if it is around long enough, including your Edelbrock. I would never say that a Holley or Edelbrock "belong in the garbage" because they are fine carburetors. I agree with you in that a Holley is going to leak more often, simply because of the design of the metering blocks on the carburetor itself. But Holleys are better known for their tuneability and racing, and the Edlebrock is known for their out-of-the-box street performance. Both are great carburetors, but you are misleading the original poster by telling him that the Motorcraft carburetors are "garbage" and are just as bad about leaking as a Holley because they are not. Their gaskets are ABOVE fuel level, just like your Edelbrock. But the Autolite/motorcraft carburetors have annular boosters (and some newer Holleys do) that atomizes fuel almost as well as modern fuel injection and even better than your Edelbrock. They are simple, reliable, good performers, and use an automatic hot air choke for better driveability. And that is why I suggested he either keep the original Motorcraft 2V he already has or go with an Autolite 4100.
Originally Posted by meborder
Just ignore him. He is simply wired that way. If you don't take his word as gospel regardless of how much or how little supporting information he provides, then he just acuses you of having your mind made up before you even asked. There are, after all, only two ways of doing things, his way and the wrong way.
Maybe I missed it, due to the back and forth going on. (but still a lot of great info) Has the OP considered a Quadrajet at all? their was a member on here that did one and loves it. You can pick them up for $20 all day long, rebuild kit is $20 if you are just looking for stock performance.
Also, here is FMC400's thread about chokes on the stock carbs: https://www.ford-trucks.com/forums/8...ml#post6939116 He kindly posted this in another carb related thread yesterday
Your post brings up another point... budget. You can probably get a solid used Q-Jet carb, rebuild kit and mainifold for less than $100. I got my Autolite 4100 off eBay for $40 with shipping, and I bought my new 4160 about 10 years ago for around $250-300. OP just got his squarebore manifold, so sticking with a squarebore carb is probably the way to go, still plenty of good options out there.
I agree that the Summit carburetor looks good. It is very much like a modern version of the Autolite 4100. All gaskets are ABOVE fuel level, it uses Holley parts, and it has the annular boosters!
Speaking of Quadrajet, I have a rather unique Autolite 4100, DrainBramage. I sent my carburetor off to Pony carburetors to get restored, and they sleeved the primaries. I now have a "spreadbore" carburetor, but only internally. This means I can use any regular squarebore intake manifold. The reason being is because 600 cfm is bit large for a 302 to begin with, and the smaller primaries help reduce the cfm to help with throttle response and better fuel mileage. With the smaller primaries and larger secondaries, I get the reliability of the Autolite, plus the benefits of a Quadrajet!
I have experiences with two Holleys.
1. A 27 year old Motorcraft Holley, nothing but problems. But then again, it was nearly 30 years old. The first thing to fail was the accelerator pump, but again.. what do you expect from a rubber part that is so old?
2. I bought a new Holley. It was a bolt on and go, no problems at all. Starts right up, with one pump of the gas. I then tap the gas again without waiting and it the fast idle kicks down, and away I go.
Why won't I buy an Edelbrock? Because of the problems I had with my first Holley, I know just about everything about them. So if I change brands then I will need to learn something new.
#29
I'll boil it down this way: How much time do you want to put into this, and how much money do you have to spend? I tend to think most 'truck guys' are like me... I'm broke and I have plenty of time to screw with things. The homebrew $60 rebuild is perfect for me. It also gives me a chance to learn more about something that most people consider to be voodoo and then I can fix it myself in the future. If you have the money to spend, (or you are rebuilding a C8OF-9510-AA for a 1968 Mustang Cobra 428CJ Shelby GT-500KR) then by all means buy a (or send it to) Pony carb, they do great work. In the end its up to the individual end user who is spending the money.
Glad the Pony Carb is working for you! I have a friend who had the original 4100 on his numbers matching "A" code 65 Mustang fastback rebuilt by Pony. It ran nice but so did my *******ized 66 with the 4160 (you will notice in my sig that it now wears a 4100...)
