1997-2006 Expedition & Navigator 1997 - 2002 and 2003 - 2006 Ford Expedition and Lincoln Navigator Discussion
2000 Expedition will not go into park
Old 09-08-2011, 10:25 AM
proudfrog's Avatar
proudfrog
proudfrog is offline
Found out last night that the X will not go into park. I am able to shift through all the gears but I can't bring shifter into park position. It stops somewhere between park and reverse but it is close enough to reverse that the reverse audio signal comes on and the vehicle will go backwards. When the vehicle is turned, the vehicle will roll when pushed.
Any suggestions?
Old 09-08-2011, 07:59 PM
gr8scott72's Avatar
gr8scott72
gr8scott72 is offline
Any suggestions?
Probably the same as an Excursion. (This IS the Excursion section, not the Expedition section.)
On the Excursion, there are some small torq screws that come loose and eventually fall out. They are under the driver's section up by the brake and gas pedals. Have someone move the shifter while you look around under. You should be able to find it.
Old 09-09-2011, 02:17 PM
Toreador_Diesel's Avatar
Toreador_Diesel
Toreador_Diesel is online now
Retired Mod
Moving to the Expedition forum....
Old 09-09-2011, 05:27 PM
Boat Tug's Avatar
Boat Tug
Boat Tug is offline
Old 09-10-2011, 08:31 AM
proudfrog's Avatar
proudfrog
Silly me. The problem is with my wife's Excursion, that is why it was posted in the Excursion forum. Anyways, all you advice came handy I was able to fix it!!! Now, I'm going to my Expedition and tighten those too!
Meagandub817
01-28-2019 02:36 PM
KayOliver
08-18-2017 04:03 PM
steven snow
11-15-2016 05:37 AM
Quick Reply: 2000 Expedition will not go into park
