Engine ID question
Old Sep 10, 2011 | 05:51 PM
Bon's Avatar
Bon
Engine ID question
On the intake manifold the number is C7TE9425G. What motor is that? I always thought it was a 352. The engine is in a 1968 F-100 4x4.
Old Sep 10, 2011 | 07:32 PM
MIKES 68 F100's Avatar
MIKES 68 F100
that number is just the manifold part number 1967
look for a tag by the coil if engine is original , otherwise only way to tell is measure stroke and bore .
Old Sep 10, 2011 | 07:38 PM
jowilker's Avatar
jowilker
Most likely if original 68, a 360.
John
Old Sep 10, 2011 | 08:53 PM
Sleepy445FE's Avatar
Sleepy445FE
Welcome to the board.
Both responses above are right. FE's are (barring a few exceptions) virtually impossible to ID from casting #s or outside appearance.
Old Sep 11, 2011 | 04:24 PM
Bon's Avatar
Bon
Thanks for the help!
I'll verify it with the ways mentioned by you all. I'll get back to you
Old Sep 12, 2011 | 09:37 PM
Bon's Avatar
Bon
Engine ID question again
I looked at the link for the VIN number If your vehicle does not have a tag on the door and it worked great. Actual VIN was on the frame right where it said it was! While doing that I saw on the drivers side of the Block, just below the head, 65 and right below that 352. Does that mean what I think it means a 1965 352 V8?
Old Sep 12, 2011 | 11:14 PM
85e150's Avatar
85e150
No, the "352" is on many FE blocks of all sizes.
Your manifold says "C7...", that's 1967, so it has to be either a conglomeration of FE parts or at least a 1967 or later engine.
Old Sep 13, 2011 | 05:21 AM
jowilker's Avatar
jowilker
Officially the 352 was dropped in 67, & the 360 introduced in 68. They both have the same 352 crank, the 360 uses the 390 bore block.
Were any 352s stuffed in 68s? dono
What are you wanting to do? Is there a reason beyond....?
John
Old Sep 13, 2011 | 08:52 AM
Bon's Avatar
Bon
I want to know what exact motor is in my 68 is just so when I order engine parts I'm accurate. From the link to the differences between the 1960's vintage Fords my 68 is not all original. Looks like the box is a 69 and with the pull type of cab heater controls and door locks and handles those look like 67.
Been learning alot since joining this group!
Old Sep 13, 2011 | 01:45 PM
85e150's Avatar
85e150
What parts are you looking at?
Tune up and external stuff is pretty much all the same.
Carb kits are the same, with slight differences explained in the instructions. (at least on the kits I used)
Old Sep 14, 2011 | 09:13 AM
Bon's Avatar
Bon
Parts needed
thanks for the reply. I will need a carb rebuild, looks like it is leaking from the accelerator pump. Some gasket is leaking oil. I tightened up the valve covers, they were loose. Both mufflers are shot, pipes not far behind. I will consider putting headers on with new exhaust if the benefits are worth it. Now is probably the time to look into it. I greased up all joints that i could get to. Power steering assist seems like it's not working like it should. Has a Garrison power assist steering system. Need to verify the power steering pump is working up to specs. Both fenders are rusted through where they all do, behind the front wheels. I can handle all the body work. Primarily going to use the truck to haul our 1963 Winnebago travel trailer. After seeing the sticker on a new F-150 of 45K wife said lets gets the 68 dependable to haul "old school Retro type" going to paint the camper white with Red Winnebago stripes. Towed by the Red 68 with the saying "Stuck in the 60's" on the back of Camper.
Old Sep 14, 2011 | 10:13 AM
Bon's Avatar
Bon
Found a metal tag at the coil. It says 360 68 1
7M 302 J
Looks to me like I have a 360 in this F-100
Thanks all
You guys are good.
Old Sep 14, 2011 | 06:27 PM
tater_51's Avatar
tater_51
Please post a photo when you have it all together. Nothing like an old Ford hauling a "period" travel trailer down the highway!
Old Sep 14, 2011 | 06:41 PM
KO1960's Avatar
KO1960
I thought my '65 was all the original parts. It started life as a 352. When I started digging in, I found that the block was a '65 390, a '67 intake manifold, and '72 exhaust manifolds. I had to measure the stroke to determine the engine size. I've since added to the confusion with my own modifications. I don't know how many people document the work they do to their truck; therefore, the story from the seller is almost never complete. I am less concerned about a original truck, since mine has been previously molested. When the truck is running well and I'm on the road, I have no concerns.
Kurt
Old Sep 14, 2011 | 10:21 PM
Bon's Avatar
Bon
Will do! It will look great!
