i bought the SRL+ tune from matt a while back LOVE the power and shifting it has.. i have one problem in the morning when i start it up i have to crank it like 8 time before it starts it keeps wanting to turn on but sounds like bad injectors or FICM... well when i switch tunes and go with elite xtream street i have no problems with it starting up.... with matts it almost soinds like on a gas car when the timing is was two advance.. any ideas?? like i said i love the tune and the power...
Since it starts fine on another tune, I would suggest contacting Matt and see what he thinks before chasing after ghosts. Have you loaded the stock tune to try? If so and it starts fine, then I would say that the tune you got from Matt likely requires a little tweaking.
What elevation are you at? High elevation? Reason I ask is that I had Elite tunes and my truck would start then die, start then die, etc. About 4 times a morning. When I got Gearhead tunes I never had an issue with that again. I swapped tunes several times and it definitely follows the tune. Only thought I had was that Elites tunes are written at 4k plus elevation.
