Sponsored by: Real Truck
something weird happen
Old Sep 7, 2011 | 10:53 PM
msriverrat's Avatar
msriverrat
This am leaving work my 2000 F250 7.3. Pulled out of parking lot and my abs light came on, turn signals stop working, overdrive light on gear shift started flashing. No speedometer. So I decided to drive to my mechanic.
Pulled in and put it in park and shut it off. Started truck back up and everything was and has been working.
Old Sep 8, 2011 | 12:33 AM
Kid Geoff's Avatar
Kid Geoff
Anything get wet lAtely?? Rain, car wash, flood?? My fuse box got soaked last week and it had the ac runnin with the key out.
Old Sep 8, 2011 | 01:14 AM
msriverrat's Avatar
msriverrat
No rain in a while. The only big change is the nite time temps have gone from 85 to 52 degrees.
Old Sep 8, 2011 | 02:39 AM
mountie's Avatar
mountie
It usually happens when the batteries lose power. But since it started right up. Hmmm, Silly question but did you clean the battery terminals/cables lately? Also check the plugs/wiring going into the computer.
Old Sep 8, 2011 | 03:08 AM
BigAlsPSD's Avatar
BigAlsPSD
Here is a possibility, the O/D cancel switch wiring is known to chafe which will cause some of the symptoms you describe, except usually you loose the throttle too? And a fuse pops. Worth checking though
Transmission O/D Cancel Switch Wiring Chafe Repair
Old Sep 8, 2011 | 07:57 AM
1973Ford2004's Avatar
1973Ford2004
I agree especially since it's the easiest thing to check
Old Sep 8, 2011 | 08:02 AM
senix's Avatar
senix
Check the VSS on top of the differential and see if it is dirty as well.
Old Sep 8, 2011 | 08:11 AM
miller_feed's Avatar
miller_feed
Hook it, I'll pull it.
I agree with Scott. Check the connection for dirt or water then if you still have the same thing going on, I would change the sensor. Napa has this VSS sensor, but they call it the ABS sensor. It's not expensive.
Let us know how it goes.
cmmnclth
18
Jan 6, 2019 09:43 AM
jredmartin
1997 - 2003 F150
May 16, 2012 10:10 PM
handyandy123
Apr 21, 2012 09:34 PM
nunya001
Aug 23, 2009 04:00 PM
