part identification help please
Old Sep 7, 2011 | 10:01 PM
96power's Avatar
96power
ok when i was working on my truck i broke this piece i have no idea what it is. Its located on the drivers side under the hood close the air intake. It is round and has a few rubber hoses that runs to it and one connecter. One of the hoses runs to the vacuum pump and one of the others runs to the brake booster
Old Sep 7, 2011 | 10:13 PM
fordpride's Avatar
fordpride
I know what your are talking about but I don't know what it called PM superduty4X4 and rodneywar they both have a OBS that they are parting out
Old Sep 7, 2011 | 10:32 PM
ccarrier's Avatar
ccarrier
can you take a picture?
Old Sep 7, 2011 | 10:34 PM
96power's Avatar
96power
sure cant =(
Old Sep 7, 2011 | 10:43 PM
Ford4Life7.3's Avatar
Ford4Life7.3
It looks like this right?
And if not exactly like that, simliar i believe, this is on my IDI. Its just a splitter from the vaccum pump that sends the vacuum to the needed places like the brake brake booster, heater core, the works. Im not sure what its called but i believe i have seen them on autoanything.com. But without the name im fraid' that dont help much. Hopefully someone else can refer to the pic for a name.
Old Sep 7, 2011 | 10:45 PM
Ford4Life7.3
Common sense would say its called a "vacuum splitter"? Just a guess
Old Sep 7, 2011 | 10:54 PM
96power's Avatar
96power
yea its close to what your picture shows but it has a large piece hooked to all that and one connecter runs into it
Old Sep 7, 2011 | 10:55 PM
rodneywar's Avatar
rodneywar
yea i know what you are talking about it is for the vac system where are you located
Old Sep 7, 2011 | 10:56 PM
rodneywar's Avatar
rodneywar
it is i think called the vacumm regulator it has 2 wires to it and one rubber hose and it is roundish looking
Old Sep 7, 2011 | 11:02 PM
96power's Avatar
96power
im located in southwest virginia
Old Sep 8, 2011 | 05:57 AM
ccarrier's Avatar
ccarrier
where in virgnia, a few of us are close to there
Old Sep 8, 2011 | 06:43 AM
DZL JIM's Avatar
DZL JIM
PREMIUM SPONSOR
You can make a replacement with some barb fittings and t's if you want, not a big deal or costly.
__________________
'96 7.3 F-350 Reg Cab 4x4 - bought new.
'04 6.0 E-350 custom 4x4
'08 6.4 F-550 Reg Cab 6 spd 4x4
'17 6.7 F-250 KR ccsb 4x4
Old Sep 8, 2011 | 07:59 AM
DIYMechanic's Avatar
DIYMechanic
If it has the wires going into it, isn't that the vacuum switch? The one that turns on the brake indicator light?
Old Sep 8, 2011 | 08:43 AM
RÖENTGEEP's Avatar
RÖENTGEEP
FOREIGN GURU
Wink
VACUUM PORT.
Front to rear on the vacuum port:
-the first goes to the pump,
-the second to the switch,
-the third small hose to the heater - air controls
-and the fourth to the brake booster.
I think the brake booster was changed in 97.
Old Sep 8, 2011 | 09:13 AM
96power's Avatar
96power
Carroll County
