Loose Steering
Old Nov 8, 2002 | 06:52 PM
geoaigel's Avatar
geoaigel
Loose Steering
Old Nov 23, 2002 | 02:46 PM
nhf72003's Avatar
nhf72003
Loose Steering
My 88 F150 short bed super cab is all over the road. It feels like the slop when going from one side to the other is exessive. seems OK when holding a slow turn on either side or holding to left on right side slanting road. What's the fix?
Old Nov 23, 2002 | 07:52 PM
MustangGT221's Avatar
MustangGT221
Loose Steering
Check the tie rods, bet they are old and loose. Also, I bet the steering box is worn and loose too. You can tighten it up with the screw on the top but not much or you'll ruin it. What happens is the gears get worn on the inside and makes everything sloppy. When you tighten them, they move and when they move, the contact patch of the gear changes which can cause it to break. I tighted mine a few 1/4 turns and it's still really loose. My tie rods need to be replaced too. On the highway I can turn my wheel back and forth about 4" before the truck will turn.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Justin - One Happy FTE Member
Old Nov 23, 2002 | 09:55 PM
larrysb's Avatar
larrysb
Loose Steering
Good question, my 94 Cargo van does the same thing at 193000 miles.
A likely suspect are the bushings in the suspension. Many people report much improvement after replacing the radius arm bushings. Certainly, tie-rod ends are a good guess. Ball joints too (if yours has ball joints). Basically though, all the bushings are suspects since they are cheap rubber parts and they get soft and mushy and make suspension.
Old Nov 23, 2002 | 11:58 PM
samhihn's Avatar
samhihn
Loose Steering
rag joint...shaft coupling for steering shaft....give it a lookin' at
Old Nov 24, 2002 | 07:47 AM
nhf72003's Avatar
nhf72003
Loose Steering
Tie rods are good, no unusuall play in front end. Rubber bushings are facotry (140K) but it feels like steering box problem. I'll take a look at adjustments in manual.
