Sponsored by: Real Truck
Same old, but different vacuum problem
Old Sep 6, 2011 | 11:13 PM
BioBurner's Avatar
BioBurner
My 02 F350 has had an issue ever since I bought it about 3 years ago. The vacuum system doesn't seem to have enough power to keep up with the Max A/C setting. It works fine (except that switchovers take forever) everywhere else on the dial, but when you switch it to Max, it will start to blow out of the mid-level vents, then slowly revert back to the defrost vents. I've just lived with it as there have been a million other problems on the truck much more important, like worn out ball joints, and steering joints.
I have also noticed that the vacuum pump seems to never shut off no matter where the A/C dial is set, so I thought "Aha! A vacuum leak!" So tonight, I opened the hood, turned the key to "run", set the A/C to Max, and started tracing the vacuum system starting at the pump. I pulled the intake hose off and plugged it with my finger, and the pump shut off almost instantly. Next, I pulled the hose off the other side of the vacuum reservoir and plugged it with my finger. The pump kept running and running and running and running. I counted to 274, lost count, and counted to back to 42 again but the pump kept running so I thought "Aha! The vacuum reservoir is the culprit!"
So I pulled the reservoir out and decided to test it on the bench. Now I am far too cheap to own a HandyVac or whatever they are called, so instead I totally wrecked the reservoir with compressed air. I put a blower nozzle on the nipple that goes to the pump and without thinking gave it a quick spritz of air. I heard the unmistakeable sound of a checkvalve flying apart and ricocheting around inside the reservoir. OOPS! I figured that it was already wrecked, so I might as well continue on with my experiment, so I soaked it in soapy water, plugged one of the nipples, and applied a slight pressure to the other one. Not a single bubble anywhere. So it turns out I probably have a weak pump, but now I have to replace the reservoir also.
Moral of the story: "Use your noodle, you damned cheapskate, or you end up spending more money than if you do things right in the first place!"
Old Sep 7, 2011 | 01:29 AM
A/Ox4's Avatar
A/Ox4
9 ECHO 1
DOH! Its ok, we've all been there.
Get yourself a $20 air pressure regulator for that compressor. That way you can test the system when you get a new reservoir in there. Plus they are also just nice to have. I have one for using on a boost leak detector.
brettdacosta
Jan 21, 2015 08:45 PM
forkhorn
May 20, 2014 07:29 PM
2000F250guy
15
Feb 5, 2014 03:37 PM
kefrko
Sep 8, 2013 07:13 AM
Roasted7
Oct 21, 2012 06:04 PM
