L.E.D. fog lights?
Old Sep 6, 2011 | 08:12 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
L.E.D. fog lights?
Is there a dot spec on fog lights? I was thinking of using a 27 watt flood or 10 watt spot, replacing my existing stock fog lights. Anybody have any insight into this? Can they be used at night to compliment the headlights? They would be equal to 65-75 watt or 150 watt incandescent light https://www.ford-trucks.com/forums/p...ictureid=79491
Old Sep 7, 2011 | 07:12 AM
High Intentions's Avatar
High Intentions
Mod Specialist ;)
I found led fog lights on ebay that are a direct replacement of the factory ones. I installed them a month ago. very happy with them, very bright. I will find the link for them and post it up.
Old Sep 7, 2011 | 06:44 PM
howler4x4's Avatar
howler4x4
Subscribed. The Ex needs a present every once in a while
Old Sep 7, 2011 | 07:33 PM
High Intentions
Mod Specialist ;)
Ok. here is a couple of pic's of my led fog/driving lights..
on in daylight
at night
Old Sep 7, 2011 | 08:11 PM
Curt's05's Avatar
Curt's05
Wiser by FTE
High intentions, that's the bomb, now the million dollar question,
from where? Thanks Curt
Old Sep 7, 2011 | 08:16 PM
Misky6.0's Avatar
Misky6.0
They look GREAT - REPS to you!!
We are all hooked - a quick ebay search reveals....
but which did you buy? Did you reuse existing switch/wires?
don't tease us any more.
$60 and also $110 they look identical whats up?
FULL POWER LED FOG LIGHTS LAMPS w/SWITCH COMPLETE KIT | eBay
99-04 F250 F350 EXCURSION FULL LED FOG LIGHTS+SWITCH | eBay
Old Sep 7, 2011 | 08:25 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
i've been eyeing those those awhile. gonna pull the trigger soon!
Old Sep 8, 2011 | 09:15 AM
fgials's Avatar
fgials
I'm following this one now!
Old Sep 8, 2011 | 10:30 AM
VaSheriff's Avatar
VaSheriff
I'm not impressed yet. The second link above advertises them as a "daytime running light". So my question is this.... how much light do they throw out after dark? Are they just bright and shiny for appearance as a daytime running light only?
Old Sep 8, 2011 | 11:37 AM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
thats pretty much what i'm assuming, and thats all i want them for since i have my fogs wired to an ignition hot for DRLs. my HID headlights overshadow my HID fogs as it is.
Old Sep 8, 2011 | 07:26 PM
High Intentions
Mod Specialist ;)
Misky. they are both the same. Just one is charging more for them. The last pic is of them at night. It's not the best pic. Will try to take one with the lights shining on something.
Old Sep 8, 2011 | 09:16 PM
jazz77's Avatar
jazz77
Have you guys gone to LED takedown & alley lights?If so how do you like them? I would think these would be comparable.
Old Sep 8, 2011 | 09:19 PM
fgials's Avatar
fgials
Did u use factory harness and switch?
Old Sep 8, 2011 | 10:22 PM
VaSheriff's Avatar
VaSheriff
I served from 1972 to 2001. Not sure what the boys use now.
Old Sep 8, 2011 | 11:01 PM
jazz77's Avatar
jazz77
OIC. Well I think the LED are brighter than the regular lights and I'm sure these would provide a similar improvement over stock fog lights. If you are looking to make them driving lights you would proly be disapointed.
