1998 Explorer Errattic Idling
Old Sep 6, 2011 | 06:20 PM
DMiles411's Avatar
DMiles411
Engine idles erratticaly after it warms up. Strong sucking air sound from throttle body as engine idles from low to high. I have no codes on ODB II. Please Help
Old Sep 6, 2011 | 08:36 PM
jplinville's Avatar
jplinville
It almost sounds like a vacuum leak
Old Sep 6, 2011 | 08:39 PM
shorod's Avatar
shorod
What have you tried to date? Are you sure the sucking sound is from the throttle body and not due to a vacuum leak? A vacuum leak, which will make a sucking sound, will also cause an erratic idle. Do you have access to a scan tool that can provide datastream results? If so, what are the short term and long term fuel trim (STFT and LTFT) numbers? Did this issue happen to just start after you checked the air filter or performed some other maintenance? You should inspect the intake air tube to make sure it is secure.
Which engine does your 1998 have?
-Rod
Old Nov 3, 2011 | 07:07 PM
DMiles411's Avatar
DMiles411
Check live data STFT = -100 and LTFT = -100. I had replaced the IAC. When I disconnect IAC engine idles normal. Re-installed old IAC engine idles high. Really using alot of gas.
RW1998
1983 - 2012 Ranger & B-Series
Jul 21, 2014 07:51 PM
contento
Modular V10 (6.8l)
27
Nov 7, 2013 10:35 PM
91Bronc300
May 31, 2009 11:35 PM
Scott D Klassen
26
Jan 24, 2007 08:26 AM
southsidej
May 30, 2005 06:22 PM
