Battery
Battery
Anyone with an older Aerostar. What have you done about the battery? Mine is 87.
Owners manual says group 64, which I can't find. I have installed a box from a 97. A group 65 is all I've found to properly fit the hold down in the box but then the terminals are on the wrong side. A group 24 has batteries with terminals both ways but it is too skinny for the box to hold it.
I used a group 65 battery and a cable stretcher to connect the cables to the battery. I did have to splice in a short piece of wire for the ground to the body.
BTW I wasn't able to find group 65 with reversed posts.
As near as I can tell a group 65 is the only battery you can use in that box. Anything else will not be wide enough from front to back to hold down the battery.
bjmayberry2
13
03-19-2016 02:53 PM
grafekie
Flatbed, Car, Boat, Utility, Horse & Misc. Trailer Towing
07-20-2007 06:23 AM
