I have two issues.
Old Sep 25, 2011 | 04:34 PM
MisterRanger's Avatar
MisterRanger
Thanks everyone.
For adjusting the tension, how do I know if it is too tight or too loose? Also, the squealing sound never occurs when the truck isn't moving. Only during movement.
As for the jerking sound, I've talked about it with my buddy. He thought about maybe the diff being to loose or the driveshaft needing to be shimmed. Well, I am not sure it is that. I am almost 99% sure it is my muffler that needs to be replaced. That nasty repair that one of the previous owners did just doesn't work. The jerking/pop sound is done when I start the truck, when I rev it and during hard acceleration. So, it might be an air leack in the exhaust system causing this.
So, I mught just go to Canadian tire, get a Magnaflow muffler or something along those lines that is universal. Then, cut that ugly stuff off and clamp on the new pipe. Alltho, what do I do with all the extra pipe left? When I am going to install the new muffler, I am gonna put it right after the cat probably since that is where the hole is. Can I just pull out the rest and let the new muffler under the cab?
dirtysouthcochran
Feb 21, 2009 02:23 PM
lurchy98
Dec 15, 2004 11:33 PM
tonyford
Nov 27, 2003 09:13 PM
S C
Jun 4, 2003 11:23 AM
StangVT66
Jan 21, 2003 12:19 PM
