Rocker cover leaks
wet coolant? are you leaking oil or antifreeze? If it is oil and it is coming from the valve covers,then yes just replacing the valve cover gaskets will fix the oil leak. The driver's side is pretty straight forward, but the passenger's side is a little trickier because you have to remove the upper intake manifold to get to the valve cover. I am assuming you are talking about the truck in your signature.
Sorry I meant to say oil. Don't know why I said coolant lol. And yes it is the truck in my signature. It's not dripping oil, it's just seeping through the bottom edges of the covers on each side. Think I'll just try tightening the bolts down and see if that works, at least in the meantime as I have a tight schedule.
bdave
10-25-2018 02:24 PM
SuperDutyScaler
1999 to 2016 Super Duty
02-06-2011 06:13 PM
