Project "No Buck"
#61
#62
#63
I believe the stuff has a adhesive tar that sticks to the floor and gives it a good seal.
For the short peices of rubber missing from LMC. could you trim the olds ones and have the new one over lap it. Then the sides would be covered. Just a thought.
But I would of thought the new ones would of extended up the sides.
I can imagine your disappointment the new ones did not. I would be.
I see the vent ports are a bit different in shape than the original. I also do not see any screw holes in the vent ports for screwing down. Do they have on the back a marking for drilling holes for the screws?
Hate to see the dash get all marreg from drilling after you painted it.
#64
Trent, how does the new pad attach? Does it just glue over the old pad? Or does it replace the old pad entirely? I will be getting one of those or similar when I get that far with my interior. I didn't know you had a silver interior, or that Ford even came out with one.
#65
So finally returned the half piece of rubber to LMC. I exchanged it with a full piece of molded industrial polyvinyl, it said it would need some trimming. That is a complete understatement, I was shocked on how much I actually had to trim off of it. However I didn't get any pictures of this process because I was actually getting a little frustrated with it. I'm hoping this upcoming summer heat will smooth it out a tad. It actually doesn't look as bad in person as it does in the pictures. As for the rest of the cab, got the new dash pad installed as well as the original door sills that were painted black. Got the seat bolted down as well as the few other panels. Hopefully get the rest of the panels and door panels on this next week. Oh, and don't mind the torn and tattered seat, hopefully with some Xmas money I can grab a seat cover. Hope you all enjoy and have a great holiday.
#66
#68
#69
I wonder if you had a heat gun when installing would of helped smoothing out the install. We use the heat gun to help bend plastics at work or to heat up glue backing on things to let go from surfaces without it tearing what we want to remove and reglue back down. Like decals.
Yes, my dad actually hauled it 100 miles to meet me half way with it. It pulls it extremely nice, however the trailer we used is small car trailer that is light weight. And the GVWR is 5120 on the Yellow ranger.
#70
Hmm, my Ranger is at 4950 with a 4.10 rear gear ratio. However my F150 is at a GVWR of around 5400, so it's a little bigger than your Flareside F100, so it may not be that good of an idea.lol.
#71
Well with some xmas money in hand I went out and bought a seat cover for the old girl. Looks 100% better, however, the seat cover didn't cover all of the brown from the original seat. So I went and purchased a can of vinyl and upholstery paint, this stuff worked amazing. For being a quick fix I have zero complaints. With this going so well it got me thinking, why spend a couple hundred bucks on new seat belts when mine are in good shape just brown in color? I went and purchased a couple more cans and started painting away on the old belts. Hopefully tomorrow I can get them put back in and everything else buttoned up for the final time, don't mind the brown belts in the pictures. I took them before I decided to paint the belts. Also had to take a picture of the new tag my old man put in my stocking for xmas, don't mind the bug guts they'll be cleaned off sooner or later.
#72
Just a little bit of an update, got most of the stereo in and done, just need new radio bezel to finish it up. In the last picture you can see the seatbelts have been updated. Instead of buying new belts that were going to cost a couple hundred bucks I decided I would get a little creative. I went and bought some fabric paint at the local automotive store and started applying multiple light coats. I think the finished product turned out great and only cost me about 5 bucks.
#74
Thanks to Gary Lewis for hooking me up with a new steering wheel insert and radio bezel. I can finally see the light at the end of the tunnel with the interior. I took both parts and scuffed them with a 3m pad, primed, and painted with gloss black. Nice and simple but it's exactly what I was looking for. As for the steering wheel, you can see in previous post that it had a steering wheel cover on it, electrical tape and a steering wheel wrap. All I can say is I believe they used at least four rolls of electrical tape. All in all the wheel was in pretty good shape with a few small cracks and one bigger crack. Since Gary helped me out with the new wheel insert it kept me from buying a whole new wheel. So, I decided budget again for fixing the crack issue. The fix being a new wheel wrap from Autozone for a whopping 7.99, and I think it turned out great. The radio bezel turned out great- with this bezel it has the stock clock where as mine didn't have that. So once again Gary helped out with this and got this all hooked up. Had a little problem with the stock connection staying connected so I just cut both ends off and added some quick disconnects, worked perfect. Once I got the cd player installed, a set of subs, and an amp that I had sitting around, it sounds awesome. So just a few more touches inside and hopefully it will be buttoned up.
