2001 F 250
Old Sep 5, 2011 | 08:02 PM
R. Lee's Avatar
R. Lee
2001 F 250
Last time pulling with truck smell coming through air vents that smelled like clutch slipping, this is automatic transmission. Thoughts on what the problem could be?
Old Sep 5, 2011 | 08:04 PM
ToMang07's Avatar
ToMang07
Could it be your brakes?
The slide pins freezing up is a common problem with these trucks.
Old Sep 5, 2011 | 08:06 PM
R. Lee's Avatar
R. Lee
This actually happen while pulling up hill, and brakes appear to be working normally.
Old Sep 6, 2011 | 08:34 AM
Brother Les's Avatar
Brother Les
Have you ever had the filter and fluids changed on the transmission? very easy job to do by a DIYer. If you want instruction, they will be posted for .
Old Sep 6, 2011 | 08:37 AM
CSIPSD's Avatar
CSIPSD
More then likely the front seal on the tranny is getting weak. They will leak when the trans gets hot and that smell goes right into the cab.
Do you have a tranny temp gauge?
Bavarskas
Dec 2, 2023 12:29 PM
Sn00zer99
Aug 28, 2011 11:04 AM
greenterror
Apr 7, 2008 11:50 AM
davisson
Sep 28, 2004 08:41 AM
