Programing Scan Gauge II
Old Sep 5, 2011 | 01:39 PM
Randy777's Avatar
Randy777
I got my new scan gauge and am trying to program it. So before I throw this thing in the garbage disposal I will ask for a little help. A couple things in the instructions are confusing. It says a nonspace entry must be made in the first character location. Does this mean 0? And it says the number of charters must be even. Does this count the nonspace entry? This thing is driving me crazy. Any help would be great. I do have the Ford codes. Just having trouble puting them in>
Old Sep 5, 2011 | 02:07 PM
BLADE35's Avatar
BLADE35
Its OK we all had to figure it out too
and yes enter the 0
they are ZERO not the letter
heres the codes
https://www.ford-trucks.com/forums/1...injectors.html
just like this
FICM Vehicle Power (Volts) (Should be 12 Volts)(should not drop below 10.25 for more than 60 seconds, or 9.0 for 4 seconds. TSB 09-24-03)
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
Inj. Control Press.
07E0221446
046205140646
3010
003900640000
ICP
ENTER ALL numbers even 0 zero
I will try and find a better one
Old Sep 5, 2011 | 02:14 PM
amdriven2liv's Avatar
amdriven2liv
I'm hitting easy street
Xgauge entering video:
Scangauge II Xgauge entering - YouTube
Old Sep 5, 2011 | 02:16 PM
amdriven2liv
Oh, and when you have entered them, the Scangauge scrolls from #24-#0 So I wrote mine done in alphabetical order for easier finding them.
You can change locations in the numbers, but we are just heading out the door, can explain later!!!
Old Sep 5, 2011 | 02:21 PM
BLADE35's Avatar
BLADE35
Im glad you did that Sean vid
Iv been getting that fuel milage dialed in I should have reset it that first fillup
Have fun with your new toy Randy
Old Sep 5, 2011 | 03:09 PM
Randy777's Avatar
Randy777
I'm still doing something wrong as my FMP is 121. Do we have diesel a or diesel b in the setup menu?
Old Sep 5, 2011 | 03:15 PM
BLADE35's Avatar
BLADE35
IIRC we are Diesel a I was going to try that one day its kinda complex
you probably just have a number or something off its really easy to do
Try this
User Manuals : Linear Logic - Home of the ScanGauge
what code are you using for FMP
FMP FICM Main Power (Volts) (Should be 47-48) TXD: 07E02209D0 RXF: 0462450906D0 RXD: 3010 MTH: 0064010000000 NAM: FMP
Old Sep 5, 2011 | 03:49 PM
Randy777's Avatar
Randy777
Benny,
Your MTH entry has 00 in front of the number I have on my sheet. Why did you add the two zeros?
Old Sep 5, 2011 | 04:15 PM
BLADE35's Avatar
BLADE35
Originally Posted by Randy777
Benny,
I just copied off an old pdf file
does it not work
alot of codes have been updated
Old Sep 5, 2011 | 04:21 PM
BLADE35's Avatar
BLADE35
heres some more dont use the boost its been updated if you have one that dont seam to read right Sean probably has an updated code he has been keeping track of them I think
FVP
FICM
TXD: 07E02209CE
RXF: 0462450906CE
RXD: 3010
MTH: 0064010000000
NAM: FVP
FLP FICM
Logic Power (Volts) (
TXD: 07E02209CF
RXF: 0462450906CF
RXD: 3010
MTH: 0064010000000
NAM: FLP
FMP FICM
TXD: 07E02209D0
RXF: 0462450906D0
RXD: 3010
MTH: 0064010000000
NAM: FMP
VGT
VGT Duty Cycle (%)
TXD: 07E022096D
RXF: 04620509066D
RXD: 3010
MTH: 00647FFF0000
NAM: VGT
EOT
Engine Oil Temp.
TXD: 07E0221310
RXF: 046245130610
RXD: 3010
MTH: 00090005F05F ( Use
NAM:
EOT
TFT
Trans. Fluid Temp.
TXD: 07E1221674
RXF: 046205160674
RXD: 3010
MTH:000100080000
NAM: TFT
HPR
Horse Power
TXD: 00
RXF: 400080000000
RXD: 0000
MTH: 000A00240000
NAM: HPR
ICP
Inj. Control Press.
TXD: 07E0221446
RXF: 046205140646
RXD: 3010
MTH: 003900640000
NAM:
ICP
IPR % IPR
Duty Cycle
TXD: 07E0221434
RXF: 046285140634
RXD: 3008
MTH: 0DCA03E8000A
NAM:
IPR %
PSI
Boost
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM: PSI
EGR EGR
Duty Cycle (Percent)
TXD: 07E022166E
RXF: 04620516066E
RXD: 3010
MTH: 006440000000
NAM:
EGR
IA2
Intake Air Temperature 2 (
TXD: 07E02216A8
RXF: 0462051606A8
RXD: 3010
MTH: 000100010000
NAM: IA2
EBP
Exhaust Back Pressure
TXD: 07E0221445
RXF: 046285140645
RXD: 3010
MTH: 001D00500000
NAM:
EBP
FL
Fuel Level
TXD: 007E02216C1
RXF: 0462451606C1
RXD: 3010
MTH: 000101480000
NAM: FL
MFD
Mass Fuel Desired
TXD: 07E0221412
RXF: 046245140612
RXD: 3010
MTH: 006400100000
NAM: MFD
VFD
Volume Fuel Desired
TXD: 07E0221411
RXF: 046245140611
RXD: 3010
MTH: 006400100000
NAM: VFD
ERT
Engine Run Time
TXD: 07DF011F
RXF: 0441051F
RXD: 2810
MTH: 0001003C0000
NAM: ERT (Minutes)
FSS
Fan Speed Sensor (RPM)
TXD: 07E022099F
RXF: 04620509069F
RXD: 3010
MTH: 000100040000
NAM: FSS
PSI
Manifold Absolute Pressure
TXD: 07E0221440
RXF: 046285140640
RXD: 3010
MTH: 012203200000
NAM:
PSI
ITM
Injector Timing Before Top
TXD: 07E02209CC
RXF: 0462850906CC
RXD: 3010
MTH: 000A00400000
NAM: ITM
FPW
Fuel Injector Pulse Width (
TXD: 07E0221410
RXF: 046205140610
RXD: 3010
MTH: 000800010000
NAM: FPW
FI1
Fuel Injector #1 Command
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3001
MTH: 000100010000
NAM: FI1
FI2
Fuel Injector #2 Command
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3101
MTH: 000100010000
NAM: FI2
FI3
Fuel Injector #3 Command
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3201
MTH: 000100010000
NAM: FI3
FI4
Fuel Injector #4 Command
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3301
MTH: 000100010000
NAM: FI4
FI5
Fuel Injector #5 Command
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3401
MTH: 000100010000
NAM: FI5
FI6
Fuel Injector #6 Command
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3501
MTH: 000100010000
NAM: FI6
FI7
Fuel Injector #7 Command
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3601
MTH: 000100010000
NAM: FI7
FI8
Fuel Injector #8 Command
TXD: 07E02209EF
RXF: 0462250906EF
RXD: 3701
MTH: 000100010000
NAM: FI8
1CM
Cylinder #1 cumulative mis
TXD: 07E022160E
RXF: 04620516060E
RXD: 3010
MTH: 000100010000
NAM: 1CM
2CM
Cylinder #2 cumulative mis
TXD: 07E022160F
RXF: 04620516060F
RXD: 3010
MTH: 000100010000
NAM: 2CM
3CM
Cylinder #3 cumulative mis
TXD: 07E0221610
RXF: 046205160610
RXD: 3010
MTH: 000100010000
NAM: 3CM
4CM
Cylinder #4 cumulative mis
TXD: 07E0221611
RXF: 046205160611
RXD: 3010
MTH: 000100010000
NAM: 4CM
5CM
Cylinder #5 cumulative mis
TXD: 07E0221612
RXF: 046205160612
RXD: 3010
MTH: 000100010000
NAM: 5CM
6CM
Cylinder #6 cumulative mis
TXD: 07E0221613
RXF: 046205160613
RXD: 3010
MTH: 000100010000
NAM: 6CM
7CM
Cylinder #7 cumulative mis
TXD: 07E0221614
RXF: 046205160614
RXD: 3010
MTH: 000100010000
NAM: 7CM
8CM
Cylinder #8 cumulative mis
TXD: 07E0221615
RXF: 046205160615
RXD: 3010
MTH: 000100010000
NAM: 8CM
TP1
Throttle Position 1 (Volts)
TXD: 07E0220917
RXF: 046245090617
RXD: 3010
MTH: 0064040000000
NAM: TP1
Note: Voltage of the ETC T
TP2
Throttle Position 2 (Volts)
TXD: 07E0220918
RXF: 046245090618
RXD: 3010
MTH: 0064040000000
NAM: TP2
TPD
Throttle Position Desired (D
TXD: 07E022091A
RXF: 04624509061A
RXD: 3010
MTH: 0064020000000
NAM: TPD
Note: ETC Commanded Th
TPA
Throttle Position Actual (De
TXD: 07E022093C
RXF: 04624509063C
RXD: 3010
MTH: 0064020000000
NAM: TPA
Note: The measured thrott
ETP
EGR Throttle Position Contr
TXD: 07E022096C
RXF: 04620509066C
RXD: 3010
MTH: 00647FFF0000
NAM: ETP
EVP
EGR Valve Position (mm)
TXD: 07E022096A
RXF: 04620509066A
RXD: 3010
MTH: 000100010000
NAM: EVP
Note: EGR Valve Position in
EVD
EGR Valve Position Desired
TXD: 07E02209D2
RXF: 0462050906D2
RXD: 3010
MTH: 00647FFF0000
NAM: EVD
EVM
EGR Valve Position Measur
TXD: 07E02209FE
RXF: 0462050906FE
RXD: 3010
MTH: 00647FFF0000
NAM: EVM
Note: MEASURED (or sense
EGV
EGR Valve Position (Volts 0
TXD: 07E022167E
RXF: 04620516067E
RXD: 3010
MTH: 000133330000
NAM: EGV
SYC
Crankshaft Position Sensor
Camshaft Position Sensor
Camshaft & Crankshaft in s
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3000
MTH: 000100010000
NAM: SYC
SYC
TXD: 07E02209CD
RXF: 0462050906CD
RXD: 3001
MTH: 000100010000
NAM: SYC
AP%
Accelerator Pedal Position (
TXD: 07E02209D4
RXF: 0462050906D4
RXD: 3008
MTH: 000100020000
NAM: AP%
BAT
Battery Voltage (Volts)
TXD: 07E0221172
RXF: 046205110672
RXD: 3008
MTH: 000100100000
NAM: BAT
CVI
VREF (My notes indicate th
TXD: 07E0221155
RXF: 046205110655
RXD: 3010
MTH: 000133330000
NAM: CVI
Old Sep 5, 2011 | 04:36 PM
Randy777's Avatar
Randy777
Hey guys I finally got this figured out. Some of the codes must have changed for my Scan Gauge. I have copied them from their site for the 6.0 Diesel and some have changed. I'm finally getting some correct readings. The only one that I'm missing is ECT which their site does not show. Hopefully I will get that one too by looking around or call them tomorrow. Thanks for your help now I can finally stop beating my head against my truck.
Old Sep 5, 2011 | 04:40 PM
BLADE35's Avatar
BLADE35
you should have ECT already programmed on SG
Its marked fWT on scan gauge but its rally just coolant temp
fWT means Farenheight Water Tempiture
Old Sep 5, 2011 | 04:45 PM
69cj's Avatar
69cj
ECT
txd = 07E0221139
rxf = 46205110639
rxd = 3008
mth = 200010000
Old Sep 5, 2011 | 04:48 PM
BLADE35's Avatar
BLADE35
I didnt know that the newer units used diffrent X-gauge codes
that new SG looks cool I was thinking of sending it in for an update
I really liked how it dialed in the fuel milage
Old Sep 5, 2011 | 05:08 PM
amdriven2liv
Those math codes for the FICM had an extra 0 for some reason. Remove the last one. There are only 12 places in the math code on those.
There are some changes that LinearLogic did with some of the codes. For example, the EOT code is different than the one I use. It will give a decimal point on temps below 100*. Also, they determined that one of the EOT codes (at one point there were 3) was off 1 degree. The one in the manual on their site works great.
