Sponsored by: Auxito
power steering
Old Sep 2, 2011 | 06:41 AM
t.duggan.photo's Avatar
t.duggan.photo
power steering
I have a 2000 4.2 5 speed. I replaced my power steering pump last year(this same weekend). When the shop replaced it I went through 3 duds in 2 weeks and finally got one that worked!.....or so I thought. It is going out now....would anyone have an idea as to why a power steering pump would go bad in a year? fluids are right and all hoses are leak free.
it is my daily driver and I have put about 8000 miles on it around town.
Old Sep 3, 2011 | 09:51 PM
Bluegrass 7's Avatar
Bluegrass 7
Discribe a bit how it acts that makes you think it's the pump.
Has the hoses been change with it?
There should be a filter in the system, maybe it's plugged.
Old Sep 3, 2011 | 10:52 PM
t.duggan.photo
all the hoses were replaced when the first pump went bad last year.
There is a squeak/squeal when I am turning my steering wheel.
I checked the filter first and it is all clear.
All the duds that got put in made a different whining noise constantly(the shop said that since the parts had been sitting on the shelves for so long not in use they just go bad) vs. right now it is a pulley squeal.
I am hoping to get it into the shop on Tues to see whats up.....
Old Sep 4, 2011 | 12:26 AM
Bluegrass 7
If the belt is on the edge of slipping and squeals, it sounds like the pump is pumping against a restriction of some sort.
Also the air has to be purged or noise can result.
I would not think shelf age would be a factor on a metal, displacement type pump.
Good luck.
Old Sep 4, 2011 | 07:42 AM
kaboom10's Avatar
kaboom10
I put a cleaning agent in mine and after that I replaced the fluid with full synthetic trans fluid. I've heard of people changing the Ford pump over to a GM pump with great results.
Mountain54
Sep 19, 2016 07:16 AM
Brandynr
20
Feb 12, 2016 11:48 AM
llh
Nov 20, 2011 09:20 PM
dcassidy
Sep 17, 2009 09:11 PM
Hi Ho
24
Sep 17, 2004 07:20 PM
