78 f250 mud truck
Old 09-01-2011, 11:49 AM
jordanbennett's Avatar
jordanbennett
jordanbennett is offline
78 f250 mud truck
hey guys, been getting lots of help of this site, i like it.
thought id share my build with you guys. its coming along been poking at it since november.
Its a 1978 ford f250 d60 front(factory- snow plow ed.)
14B FF rear with Detroit locker and disc conversion
just dropped in a :
1970 ford 460 big block
-d0ve block
-Keith Black hypertechtic pistons
-comp cam 260
-double roller timing chain
-comp springs and retainers
-D0VE heads with a port clean up and good valve job
-magnum rockers
-stock crank and rods with arp bolts
-balanced
-edlebrock performer intake
-770 holley truck avenger carb
connected to a t18 4 speed and np205 transfercase
very close to finishing, just got to through the 14b in the rear with some 63''
chevy springs and a fabbed wrap bar
and finished the wiring for the motor.
here are some shots:
front d60
rear 14ff
as she sits right now
Just getting an understanding on what to do for pulleys from you guys! big thanks! so going to try and tackle that, and then figure out my steering
i hear theres alot of issues with running a crossover with that huge crossmember that hangs down.
thanks for your time guys!
hope you like
any tips ticks ideas complaints please let me know!!
Old 09-01-2011, 11:01 PM
73 ford guy's Avatar
73 ford guy
73 ford guy is offline
Lookin good. Is the front diff open with stock 30 spline stub shafts still? Do you plan on running crossover? Is it strictly for straight lines in the mud or are you wheeling trails and rocks as well?
Post a pic up of the traction bar
Old 09-01-2011, 11:03 PM
monster79f150's Avatar
monster79f150
monster79f150 is offline
Very nice ride! I'm thinking about putting a 460 in my truck too one day, can't wait to see how it goes!
Old 09-01-2011, 11:12 PM
jordanbennett
well mud drags are a forsure, but im going to try and keep up with my yota
buddies, haha (tree smashing) but yeah open 30 spine for now, would like to do the 35 spine swap and a detroit up front, gunna run 63'' chevies in the rear. so it will have lots of flex and running rear f350 leafs bewards in the front the push my axle 2'' forward.
ill grab a photo tomorrow of the track bar
Old 09-01-2011, 11:13 PM
jordanbennett
yeah man its hard its ups and downs but i cant wait to see it run!
been sitting since boxing day when i blew up the original 400m
Old 09-01-2011, 11:22 PM
73 ford guy
Might need a exo cage to save some sheet metal. I'm more than half done mind that'll be done this weekend. As for that carb hopefully it works good for you. My 428 cj I had one, worked great offroad but at high rpm slamming throttle it had a major flat spot. Messed with it a bunch but eventually Holley tech recommended a 670 TA and it solved my issues. Reason was he said my motor didn't have enough engine velocity( too small I guess) to pick up check ball in metering block. Hopefully yours is ok. Also it comes with a 2.5 powervalve so you may want to run a idle vacuum test and see if you could use a 6.5 ish as its pretty low.
Old 09-01-2011, 11:24 PM
monster79f150
Ohh don't say that! I have a 351M in mine and can't afford a blow up! she's a little beefed up but i'd prefer the sweet torque of the 460 to keep those wheels turning, good luck in the pits!
460 FORD MAN
Offroad & 4x4
95
10-04-2012 02:14 PM
ArrizX
Offroad & 4x4
244
09-05-2012 09:20 PM
Vean555
05-11-2012 11:55 AM
Ford4Life7.3
04-25-2012 08:51 AM
Tha_Stepside
28
06-13-2008 12:18 AM
Quick Reply: 78 f250 mud truck
