Anybody here like Tractors? Ot but ford
Any tractor is dangerous. I cannot tell you how many close calls I've had over the years. The calcium fluid in the rear wheels helps. And obviously a roll bar and seat belt are good ideas. But I am telling you, at any point in time, there's about 14 different ways to die instantly when operating one. My Kubota has all the things like calcium, rollbar, etc. I turned a corner too sharply with a hay bale on the front about a year ago. I witnessed the left front come off the ground about 2 feet instantly. My life flashed before my eyes. Get the best and safest thing you can afford. Because most tractors end up being a lifetime deal.
Now to my other point. And this might upset the Ford faithful here. The 8N's and 9N's are wonderful tractors. Hell they made a zillion of the things way back when. BUT, if you plan on using it to plow a vegetable garden or do something else at a very slow speed, they just simply are not equipped to do so. They're just not geared to slow down enough to do a good job at tasks like that. I say this from direct experience. Otherwise, they're good tractors if you want to use it to scrape a driveway or pull a hay wagon, etc.
I loved the 8N due to its simplicity, ease of maintenance, and excellent handing over hilly terrain; parts are still readily available. It did have some problems like poor rear axle seals that will leak fluid onto the brakes and the lack of a live PTO. I installed an overrunning clutch for safety.
I completely restored that tractor and hated to sell it when I moved from Virginia. There is something about sitting on an old tractor and doing some “man’s work”, even if it’s only cutting grass. God, I miss that tractor.
There may be a little “Green Acres” in all of us.
P.S. I also purchased a Belarus tractor. Please don’t ask about it!
Ya need to keep in mind this thing was made to PULL airplanes around on a airstrip. I have seen and driven these but never seen one with a loader bucket. Would be fun to look at but limited usefulness unless you need to turn around your B52
As far as the 8 and 9 n's they were popular because they were cheap and easy to get parts for and work on. Many car and truck parts fit the 8 and 9 n tractors. They were not really much of a tractor. Not much power and everything wore out quickly. Case, IH,John Deere, and others were a much better tractor and lasted many times longer.
That being said it would be cool to have around.
Thanks guy's; lots of good advice here. it is a cool old tractor but I guess I should have more space before I get one... I only saw it becasue of the flathead V8 in it. and I don't really have the extra 1100 laying here, and if so would be better spent elsewhere anyway...
don't have a B52 but could tug my f-6's around with it
That unit should have a build tag on it somewhere. Maybe a wagner loader conversion. Not a tug at all, loader specific. I've looked at least 3 of those units over the years, and most were rusting hulks that were priced at about $2,000 The hydraulic cylinders are power up only, gravity down. NOt very good at digging, need practice doing that. Good at scooping loose piles.
Can anyone tell me the overall width of an 8N? I'm looking at getting a tractor, too, but only for pushing back my snow piles from the plow truck, and for lifting cabs and engines, and such. I'm hoping to find one that'll fit between my house and garage, yet lift the weight of about 800-1000#
Me too. I've lifted things a LOT heavier than a car body with mine. My old Massey Ferguson will also lift a lot of stuff with a boom pole on the rear 3 point hitch. The only problem with lifting from the rear is you don't have as much lift capacity and it's very hard to lift something like that high enough. If you are seriously wanting to lift and move a lot of stuff, definitely get a front end loader.
#28
#29
