British Columbia British Columbia
Join Chapter, Leader: sky Cowboy
What have we done to our trucks today B.C.?
Old 05-04-2013, 06:05 AM
Zip's Avatar
Zip
Zip is offline
This week I put on some new plug wires, gave her a bit of grease, hooked up the window washer wires. Noticed I have a rear ujoint that will need some attention sometime soon.
  #77
Old 05-06-2013, 08:45 PM
Vadis's Avatar
Vadis
Vadis is offline
Part hunted over the weekend and found a new dash, door panels and steering wheel for my '79. Researched some more about swapping in a '91 351w from a donor truck I should be picking up this coming weekend.
Now just waiting on the last couple parts for my Holley 4160 to come in, nothing like a 4 week back order to kill progress on projects
Still on the hunt for a rear drive shaft. It's got to be some rare length because out of a dozen 4x4 dents I've check it's quite a bit longer then those
  #78
Old 05-11-2013, 07:21 PM
Vadis's Avatar
Vadis
Vadis is offline
Picked up the 1991 F-150 engine donor truck today. Looking forward to tearing into it soon.
  #79
Old 05-15-2013, 09:37 PM
429unibody's Avatar
429unibody
429unibody is offline
Added some Bling to my Ego Booster yesterday and went and picked up a Ducks Unlimited inflatable canoe today
  #80
Old 05-15-2013, 11:07 PM
Zip's Avatar
Zip
Zip is offline
Finished putting in the grill and surround on the bronco. Going to install the coolant filter on the big white truck.
  #81
Old 05-27-2013, 12:09 AM
smegg's Avatar
smegg
smegg is offline
I went junk yard pickin, am looking for plugs and harness for trailer lights/brakes. plus a few other things that I might discover. . Sad most of the wreckers here on the Island no longer have older model trucks . mostly 99 and newer. so parts are getting slim here now. But the nice weather makes the hunt nice .
  #82
Old 08-09-2013, 08:54 PM
R031Kona's Avatar
R031Kona
R031Kona is offline
Been busy, had the transfer case shiftmotor blow so I converted her back to manual shift , had to take the extension housing off the old transmission, also installed a lunchbox locker for the front to match the rear one and am now true 4 wheel drive.
  #83
Old 12-10-2013, 04:04 AM
Zip's Avatar
Zip
Zip is offline
Month ago put in a couple seals on the left front axle. I had a seal that was toasted. It seems that seal helps keep the axle from being wobbly. I had a horrid noise when in 4wd. Thought it was about time to fix the problem.
That fixed a bit of the noise. On to the front driveshaft. Thought it might be a ujoint till I pulled it. Turns out there is a little thing called a ball kit in the cardan joint. It was basically cooked. All back together and runs nice and quiet.
Picked up a used Scan Gauge II this afternoon. Next step is to add the gauges I want to monitor.
  #84
Old 12-11-2013, 03:28 AM
brickie's Avatar
brickie
brickie is offline
What did the scan gauge cost ya Chris?
  #85
Old 12-11-2013, 03:31 AM
Zip's Avatar
Zip
Zip is offline
I paid a hundred bucks. He used it for about 3 weeks then picked up an Edge CTS.
  #86
Old 12-11-2013, 03:34 AM
brickie's Avatar
brickie
brickie is offline
Sweet . Bang for the buck (retail)there is nothing even close for gauges. You grab it for the 6.0 I assume.
  #87
Old 12-11-2013, 03:40 AM
Zip's Avatar
Zip
Zip is offline
Yep. Still got the old heap. I have been toying with the idea of getting one for a while now. Was searching on Castanet which is kind of an Okanogan form of Craigslist. He was asking 125. I asked if he left any wiggle room and he dropped it to 100. I'm pretty happy with the price.
  #88
Old 12-11-2013, 03:44 AM
brickie's Avatar
brickie
brickie is offline
Half the price I paid. Hows the 6.0 been treating you anyway?
  #89
Old 12-11-2013, 04:03 AM
Zip's Avatar
Zip
Zip is offline
Since the FICM last year it's been good. I did the blue spring this summer. No engine issues at the moment. Spent some bucks on ujoints, ball kit and some seals for one axle. Over all I'm pretty happy with it.
My wife is sometimes after me to get something newer. Have not seen anything that would make me want to do it.
  #90
Old 01-01-2014, 05:03 PM
Zip's Avatar
Zip
Zip is offline
Got the rear shocks changed, now on to the fronts. Then windshield washer nozzle and some new wipers.
Quick Reply: What have we done to our trucks today B.C.?
