1978 - 1996 Big Bronco
Exploding glass!
Old Nov 2, 2011 | 06:36 AM
v8xploder's Avatar
v8xploder
Good info, my glass should be here today, for now I'm going to try to fix my existing talegate. Anything else I should need while I'm in there? Motor and every thing works great so that should be fine
Old Nov 2, 2011 | 12:15 PM
b4hntn's Avatar
b4hntn
Clean and lube tracks on bottom of glass per greystreak's suggestions. Then spray glass channels with dry lube.
Old Nov 2, 2011 | 06:42 PM
v8xploder's Avatar
v8xploder
Of course the heat element on the glass was broken, so I had to turn the back glass down. the guy at the salvage yard is trying to locate a different one for me. One question for when I do finally get new glass- should I use my rivet gun to put the channel rollers back on the glass or should I use bolts like someone I read about at super motors did...id feel safer with bolts, It just seems my hand held rivet gun would break the glass before the shank of the rivet cuts off.
Old Nov 2, 2011 | 07:10 PM
Edgethis's Avatar
Edgethis
I have bolts on mine. Makes it much easier to also remove the window if needed.
Old Nov 8, 2011 | 05:46 PM
alrowley's Avatar
alrowley
Smile
Originally Posted by FourXFord2
I climbed into my 91 bronco this evening on my way home from work. When I closed the drivers door, the tailgate glass exploded! Nothing was touching it, the window was up. weather stripping is in fair condition. Has anyone else heard of this happening?
I have. My tailgate and driver door glass are gone due to this issue.
Old Nov 26, 2011 | 12:02 AM
graflexmaster's Avatar
graflexmaster
Reading this thread made my day....... as I just finished replacing the rear window on my 85....... Over the years I've replaced WAY too many Bronco rear windows to count (3 of my own and untold numbers of cust when I worked for Ford) lol.
Yes, the primary reasons for the breakage are either a mis-aligned top, a faulty limit switch....or my favorite....... a faulty/defective window motor where you need to lift the top in order to release the tailgate, with a high probability of flexing the glass causing it to shatter.
When I worked in the dealership, cutomers were always told that in order to open the tailgate to access and replace the bad window lift moter, there was a high probability that the window would break and need replaced as well.......
Michael
Old Nov 26, 2011 | 05:29 AM
b4hntn's Avatar
b4hntn
What is the best way to adjust the tailgate alignment? I'm going to the Help! section at the parts store today for tail gate striker bushings. While I have the striker bolts off I want to align properly.
Old Nov 26, 2011 | 05:43 AM
miottimouse's Avatar
miottimouse
well at least i am not alone haveing these back window problems my glass does not line up at all on the top and wants to go on the inside of the rubber almost like the canopy needs to go forward i am not sure what to do now i replaced the rear window channel rubber and the canapy/cab seal when the truck was painted last month i tighten up the canopy to cab bolts till they just about broke the only thing i can think of is ajusting the gate striker bolts to get the gate to come out a bit on the top but at 32 yo the 2 bolts are seized solid is there any movement possable for these strikers on a 79? i could drill&tap but there is no use if they dont move please advise if some one knows
Old Nov 26, 2011 | 04:32 PM
FourXFord2's Avatar
FourXFord2
While I'm here might as well update.
Last weekend I guess I added another reason for rear window glass exploding. I had just gotten my 91 unloaded from a hunting trip, and was inside my house relaxing and telling stories to my wife when we hear POP POP POP! Someone drove by and fired 3 shots from a 22lr at my bronc parked in the front yard! SOB!!! We rushed out all we could see was the tailights. In the rush I forgot to grab my 30-06 which still had 4 shell in the mag. Lucky for him I guess. Anyhow now I have to replace my windshield, backglass and a headlight bucket thanx to this punk. As well as a passenger window and windsheild on my 76 F150 from a previous hit.
Old Nov 26, 2011 | 04:49 PM
Edgethis's Avatar
Edgethis
That is a damn shame. I've been down that road before. Hopefully you can catch them or stop them.
Old Nov 26, 2011 | 05:02 PM
v8xploder's Avatar
v8xploder
Yikes, glad no one was hurt. find that idiot and put some -06 rounds thru his radiator. You can borrow my win mag too
Old Nov 27, 2011 | 01:08 AM
ford1977owner's Avatar
ford1977owner
this happen to my dad when he put the back window down in a parts bronco for mine, window went down fine, but when he put the tailgate down( didnt slam it or let it drop) it just went POOF
Old Nov 27, 2011 | 02:34 AM
  #28
rollerstud98's Avatar
rollerstud98
When we had a bronco, I was using the key to bring the window down and it just exploded on me, we had the truck for maybe 3 more years after that and never had another problem with it.
Old Nov 30, 2011 | 12:33 PM
  #29
BRONCO2BCN's Avatar
BRONCO2BCN
mine broke one cold winter night no alignment issues just brutal cold.the window tint film held it together though.
Old Nov 30, 2011 | 03:52 PM
  #30
ErrorS's Avatar
ErrorS
This thread better not have jinxed me.. if my back window breaks I'm gonna be mad
