'96 Bronco needs new engine . . .
We want to go affordable . . . but not cheap! If you know what I mean.
Not sure if we should go short block, long block, crate?
How do we identify engine to get the right thing?
We have the tools and experience to do this, but which way would provide best bang for the buck?
Can you recommend (or not) any particular companies to buy from?
I just got a quote form this place www.cmengines.com for a long block
for my 1993 bronco 5.0 about 1100 plus core also go off of the vin# to get the proper one
Displacement is embossed in the upper intake plenum on these things. That part is easy. 96 is the first year OBD-II engine management system was employed on ALL Bronco models. There were only two OEM mills used in 96 anyway (5.0 & 5.8).
I'd suggest long block. If you are gonna replace it, might as well have everything that can be redone/new be that way and done by the same folks.
HDCRAZYMAN
1978 - 1996 Big Bronco
Apr 10, 2011 02:55 PM
97powerstroke
May 13, 2007 01:14 PM
