body lift
Old Aug 29, 2011 | 11:09 AM
sju96ford's Avatar
sju96ford
body lift
Ive decided i cant afford a suspension lift right now but still want to lift my 93 f250 7.3 4x4 so im trying to figure out what is the best way to body lift it. Please let me know what you guys have done and what works and what doens't. Anything helps. Thanks.
Old Aug 29, 2011 | 12:08 PM
MUJA1001's Avatar
MUJA1001
puck it homo
Old Aug 29, 2011 | 12:29 PM
joe f350's Avatar
joe f350
i say save up do it right the frist time. you can do it to ways. the cheap way or the right way. ur choice
Old Aug 29, 2011 | 06:45 PM
91dirtydiesel's Avatar
91dirtydiesel
what size lift did you have in mind?
Old Aug 30, 2011 | 12:09 AM
catfish101's Avatar
catfish101
I made mine out of solid aluminum on my lathe. I think I could go 1 3/4" without put anything in a bind. Steering shaft, ETC. I will have to double check my measurements though.
Old Aug 30, 2011 | 08:46 AM
sju96ford's Avatar
sju96ford
id like to go several inches if possible
Old Aug 30, 2011 | 09:50 AM
91dirtydiesel
2? 4? 6? 8? What's several mean? Depending on size and budget there are a few ways to achieve lift.
body lift, lift springs and brackets, or doing the dana 60 swap, ect. What size tires you want to run?
Old Aug 30, 2011 | 11:46 AM
Dodge/Cummins's Avatar
Dodge/Cummins
The tallest body lift EVER rocommended is 3" and then you have modifications to shifters, filler neckes etc.
Old Aug 30, 2011 | 12:06 PM
ihateminimumwage's Avatar
ihateminimumwage
Wait and save to do a good suspension lift. They aren't that bad it you DIY it instead of a kit. Are you lifting it because you need the clearance off the pavement, or are you just doing it for looks?
If you just need a quick and easy, put in some F350 flat springs up front, or just install add-a-leafs all around and get it aligned. Should hold you over until you can do it right.
Old Aug 30, 2011 | 12:07 PM
91dirtydiesel
I went to look at a truck on craigslist and believe it or not 8" bodylift, ill post pics when I get home. Looks so trashy
must be nice to be able to pull the heads off with out opening the hood lol
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=blford.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/blford.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=blford2.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/blford2.jpg" border="0" alt="Photobucket"></a>
<a href="http://s1095.photobucket.com/albums/i463/91dirtydiesel/?action=view&amp;current=blford1.jpg" target="_blank"><img src="http://i1095.photobucket.com/albums/i463/91dirtydiesel/blford1.jpg" border="0" alt="Photobucket"></a>
Old Aug 30, 2011 | 01:52 PM
sju96ford's Avatar
sju96ford
probably 3" body lift. I have 285 75 16 on there right now and will have them for a while.
Old Aug 30, 2011 | 01:53 PM
sju96ford's Avatar
sju96ford
mostly just for looks i guess
Old Aug 30, 2011 | 04:14 PM
Lil Red Sled's Avatar
Lil Red Sled
Body lift is nothin but problems and doesn't look good
Old Aug 30, 2011 | 08:06 PM
kenpobuck's Avatar
kenpobuck
I have mine body lifted 4". This allowed me to fit my 37's with ease and keeps all that frame engine etc. wieght down low. I made mine from 2 1/2" sch 40 pipe with welded in washers at both ends. I had to add 2" to my steering shaft and 4" to both the trans and tcase shifters. The truck is as stable around curves and corners as it ever was and that is with out any sway bars. It also allowed me to keep the hitch as close to stock hieght as possible with the 37's.
Old Aug 30, 2011 | 08:18 PM
Otahyoni's Avatar
Otahyoni
Kenpo, you have more mounts than us truck guys...
I'm going to keep that in mind though cause i'd like to lose the lift, but i want to keep my tires....
