FUEL FILTER HELP!
Old Aug 28, 2011 | 07:15 PM
Midnite1987's Avatar
Midnite1987
FUEL FILTER HELP!
Ok i have tried twice now to change my fuel filter....
i have a tool for 5/16 line that worked great on the fornt side of the filter but i cant for the life of me get the back connection off and the filter out of the bracket.
any help would be appreciated ad i now have a big dent in the fuel filter from trying to get it out of the bracket.
i really don't want to have to bring it to a shop to have it done but its beginning to look like that is whats going to happen....
help! please
i have dual tanks if that makes any difference....
Old Aug 28, 2011 | 08:21 PM
bigblockford_390's Avatar
bigblockford_390
I just changed mine this afternoon on my 97 F-250 short box with dual tanks and what a Bi### it was to do. I had good luck with getting a pair of pliars up there to twist on the hose just to free it up. Then I installed the tool and I used two pry bars, one to push against the fuel filter and the tool to press the tool into the line, and then the second pry bar pressed against the tool and the line and it popped right off. Basicly the tool was sand-whiched between two pry bars, with one pushing the tool and the other pushing the line. I had tried to push the tool with one hand and use the pliars to push on the line with no luck.
It is too bad Ford did not move the filter 6 inches closer to the front, on mine it was right next to the mid ship fuel tank which made access even worse, but then again maybe they are this way on all of them.
I hope this helps!
Jeff
Old Aug 28, 2011 | 08:27 PM
Midnite1987
i just cant seem to get my fricken hands in there to do it. and the fact im laying on the gravel driveway doesnt help either....
Old Aug 28, 2011 | 08:35 PM
bigblockford_390
Im not sure what tool you are using, but mine is the metal one about 4 inches long and it pivots in the middle and has different sizes on each end. I am able to slip that tool up and get it over the tube on the end of the filter and pushed in against the spring. Then I get the pry bars up and it came right apart.
If you have those disconnect tools that is only for one size and is basicly a half circle, I could see how that is harder to get up as there is little to no room between the fuel tank and filter.
Jeff
Old Aug 28, 2011 | 08:40 PM
Midnite1987
i have the 5/16 one of these ones. but theyre only about 2" long
Old Aug 28, 2011 | 11:41 PM
bikeymikey's Avatar
bikeymikey
did you try the 3/8 inch one? i just did the fuel filter on my 1994 f150 4x4, and the 3/8 was the ticket.
Old Aug 29, 2011 | 12:20 AM
bikeymikey's Avatar
bikeymikey
oh and i used an open ended wrench to press the tool into the coupling on the of the filter (filter was super close to the fuel tank, not much room for my hands... ) popped right off.
Old Aug 29, 2011 | 01:29 AM
SideWinder4.9l's Avatar
SideWinder4.9l
2 additions on this matter I'd like to add...
1)-Relieve the fuel pressure.....So as not to get a nice burning face full of petrol....
2)-After doing #1....Do Mikeys way, and use another tool (Large handled screwdriver, or a small household hammer) to SLIGHTLY tap the OE wrench....To help break tension...
Also, soak it in PB Blaster.....
Old Aug 29, 2011 | 03:22 AM
Slip ford man's Avatar
Slip ford man
If the skid plate is limiting your hands, try dropping it down on the rail side. The only way that I can change mine, is to lower that plate down.
Old Aug 29, 2011 | 07:47 AM
Midnite1987
I don't have a 3/8" tool so maybe that's my issue... A guy up the road Sao he would change it for $20 so I dropped the truck off there last night lol for $20 it Isnt worth fighting with it to me
ajordan193
Modular V10 (6.8l)
Jun 27, 2008 12:30 PM
rookiewithford
1997 - 2003 F150
23
May 12, 2008 10:40 PM
mike L
Sep 28, 2007 07:16 AM
Spaggs
Jun 2, 2007 09:47 AM
kev100
Mar 12, 2003 02:52 PM
