Stumble on Deceleration
Old Aug 28, 2011 | 06:58 PM
devino246's Avatar
devino246
Ive been having this problem for a few weeks. The truck is a '79 F150 w/ 351m and C6. Ive tried adjusting the dashpot, idle speed, and idle mixture to no avail. Im reading around 20-21hg in neutral and 16-18 in drive-not really sure how good those are. Timing is set to spec, emissions components are intact; although I did pull the cat off, take the insides out, and put it back on. On a possibly related note, Ive been experiencing hard downshifts on occasion. I pulled the vacuum line off the vacuum mod and theres no sign on trans fluid. Any help?
Old Aug 29, 2011 | 01:49 PM
devino246's Avatar
devino246
Anyone? It happened several times on the way home from school. Seems like it only happens at lower speeds.
Old Aug 29, 2011 | 02:16 PM
co425's Avatar
co425
Check your float levels. That's the only thing I can think of.
Old Aug 29, 2011 | 03:17 PM
devino246's Avatar
devino246
It seems a bit unusual that its just started doing this recently. I double checked the float level in June when I rebuilt the carb, it should be good.
Old Aug 29, 2011 | 04:22 PM
Lil Red Sled's Avatar
Lil Red Sled
Can I get a little more detail on what's exactly happening
Old Aug 29, 2011 | 05:08 PM
devino246's Avatar
devino246
Upon letting my foot off the gas, the engine rpm drops and the vacuum drops down close to 10hg. It sounds like its gonna die but then starts back running good again. It only does it at lower speeds, maybe only in first gear, although Im not 100% sure.
Old Aug 29, 2011 | 05:29 PM
Lil Red Sled
I had the same type of thing with my 351w. Lettin off the gas it would stumble and shake. Turns out the air/fuel mixture screw on one side wasn't working. Replaced the carb and it all went away
Old Aug 29, 2011 | 06:10 PM
devino246's Avatar
devino246
Oh joy, partial carb rebuild this weekend then.
Old Sep 1, 2011 | 04:25 PM
devino246's Avatar
devino246
Hmm, so I went to Advance Auto to get some Sea Foam and talked to the parts guy while I was there. He suggested replacing the trans. modulator and maybe finding a new dashpot. I just orderd a new modulator so Ill put that in tomorrow and see what it does.
Old Sep 5, 2011 | 05:53 PM
devino246's Avatar
devino246
Replaced the trans mod, started driving down the street, had to turn around. Took the carb off a blew out all the passages. Runs better now but still stumbling. Adjusted the dashpot almost all the way out a while ago; ill see what that does in the morning. If that doesnt change anything, its probably gone and Rockauto has them for $10.
Old Sep 6, 2011 | 09:42 AM
toymobile's Avatar
toymobile
check float level in carb to high could cause that good luck,
Old Sep 6, 2011 | 01:47 PM
devino246's Avatar
devino246
I just checked it yesterday, was 16/32. I just noticed something that I hadnt noticed before, a ticking noise coming from the right valve cover could these two things be related? Sticky lifter? Bent pushrod? Burned valve??
Old Sep 6, 2011 | 05:35 PM
devino246's Avatar
devino246
Anyone??
Old Sep 7, 2011 | 04:34 PM
devino246's Avatar
devino246
Checked the compression on the 1-4 cylinders:
1-135
2-155
3-140
4-145
Not sure if thats good or bad, but that would rule out a sticky lifter or bent pushrod, right?
Maybe Ill check my wet float height later and see what that is...
lvin4jc
44
Dec 6, 2014 11:29 PM
CarolinaCanes
39
Dec 31, 2013 07:25 PM
Greyf100
Apr 21, 2012 06:40 PM
mnjarhead
17
Jan 7, 2008 11:58 AM
UncleJesse
Mar 11, 2004 09:20 PM
