Cams and vacuum
Old Aug 28, 2011 | 05:59 PM
lasg4's Avatar
lasg4
Cams and vacuum
Looking for info on what cams everbody is running and the vacuum they are pulling. We have two classes in the mud drags that pull 19 and 17 inches for street trucks. Just tring to get a some info for a cam selection. Thanks
Old Sep 3, 2011 | 08:07 PM
danlee's Avatar
danlee
I pull 11" in my 434.
Old Sep 3, 2011 | 09:13 PM
lasg4's Avatar
lasg4
What cam are you running.
Old Sep 3, 2011 | 09:26 PM
danlee's Avatar
danlee
It's a custom HR from Comp Cams. It has 0.600I/E lift, and 273/299 Seat-to-seat, 224/244 @0.050" duration. The LSA is 114 degrees, and the overlap is about 58 degrees.
Ordinarily that overlap should produce more vacuum, but the ramp rate is so high for this cam that the valves are at a higher lift longer during the overlap period.
Old Sep 4, 2011 | 08:13 PM
wyoming4x4's Avatar
wyoming4x4
cam stuff.
If you get with some of the custom cam companys they may know how to get the most bang for the buck situation for you. Buying just off the shelf stuff works pretty good but having a guy do a little majic for you would be a little better. I run the MPG heads/cam research stuff and maybe scott can do some majic check him out.
Old Sep 5, 2011 | 05:01 AM
danlee's Avatar
danlee
You should consider a Comp Cams DEH-265. It has only 50 degrees of overlap, and should give you good vacuum.
Old Sep 5, 2011 | 06:35 PM
crsmiffy's Avatar
crsmiffy
I'm running the 265 DEH in my 400. Yet to put a vac gauge on it but everything vac operated brakes etc all ok. I have a gauge but car in bits so haven't tried it yet but will post soon when I do.
Old Sep 6, 2011 | 08:24 PM
lasg4's Avatar
lasg4
Thanks for all the input keep them coming.
Old Sep 19, 2011 | 12:40 AM
crsmiffy's Avatar
crsmiffy
put the vac gauge in over weekend. At idle in gear 11" and foot on the brake. cruising at 60mph can sit 15-16". Light throttle 45-50mph close to 20". This is with dual pipes but factory headers, 302cc aussie heads ported to gaskets with 4V valves, Holley street Dominator single plane. 3/4" spacer, 725 Holley vac sec carby, 425 impco lpg mixer fitted for duel fuel and most importantly a 265DEH comps cam.
Old Sep 20, 2011 | 07:47 PM
lasg4's Avatar
lasg4
What is it pulling at idle in park? Thanks
Old Sep 20, 2011 | 07:52 PM
crsmiffy's Avatar
crsmiffy
idle warm and in park it is 11-12"hg. In gear foot on the brake it is closer to 10"hg. Sorry my fault for the previos incorrect reading. drops just over a point due to extra load.
Old Sep 22, 2011 | 04:50 PM
crsmiffy's Avatar
crsmiffy
How did you get on?
fly-tying.guy
Jun 8, 2014 06:55 PM
Todds79
Feb 23, 2008 05:42 PM
73F100*8Mile
Jan 22, 2008 09:40 PM
428HIGHBOY
40
Sep 4, 2007 10:05 PM
71FoMoCo
Apr 26, 2003 12:07 PM
