DIY Traction Bars
Old Aug 28, 2011 | 05:06 PM
4CFarms's Avatar
4CFarms
DIY Traction Bars
I have 1997 PSD and i wanted to fabricate my own custom traction bars in the rear to save some money. But something that really has kept me from doing it thus far is that once you mount them, then will the radius of the bars obstruct and damage the up and down movemnt of the leafsprings and axles. I really need some input from someone who knows about this cus i want to make sure i cure the axle wrap and not PRODUCE a worse problem... Thnaks, Luke.
Old Aug 28, 2011 | 07:00 PM
IowanStraight6's Avatar
IowanStraight6
If done the right way yes there was a arrival in the last diesel power about traction bars on a white 97 psd
Old Aug 28, 2011 | 07:22 PM
TC-Countryboy's Avatar
TC-Countryboy
I don't know how much help I can be but a while back in Four Wheeler magazine, I believe, they had and article on adding a single bar. I was mounted as close to the differential housing as possible then ran forward to a custom crossmember. At the axle it was mounted with a bushing on bottom and heim joint on top for adjustability. The front had a bushing as well, but instead of mounting directly to the crossmember, it went to a shackle above the crossmember. The shackle allows the bar to prevent axle twist as intended, but allows some movement back and forth with the normal movement of the axle. If I am not mistaking, the components came in a do it yourself kit that you order the kit and tell them the length of tubing needed and they send you all the parts for you to weld together and install.
TC
Old Aug 28, 2011 | 11:53 PM
86F150302's Avatar
86F150302
Maybe this will help you would or at least give you some ideas.
Traction bar build thread - The National Lightning Owners Club Inc
http://www.nloc.net/vbforum/gen-1-li...-finished.html
Traction Bars Finished *PICS* - The National Lightning Owners Club Inc
Old Aug 29, 2011 | 03:54 PM
4CFarms's Avatar
4CFarms
thanks alot for the links, im gonna do back to the drawing board...
Old Aug 29, 2011 | 04:01 PM
85e150's Avatar
85e150
Look at these. Might be easy to duplicate. I think they explain their geometry etc so you can get some ideas. These are adjustable also.
Calvert Racing - The Leader in Leaf Spring Innovation
Old Aug 29, 2011 | 04:12 PM
lew52's Avatar
lew52
I use the cal tracs , they work very good , with them no wheel hop or spring wrap ...
Old Aug 29, 2011 | 04:42 PM
Conanski's Avatar
Conanski
I'll add that technically it's a little better to mount this type traction bar above the axle instead of below, that puts the bar under tension(stretching) stress when the axle tries to twist instead of compressive stress where the bar has to be much beefier to prevent bending. I don't know how practical it would be but you could even make an above axle traction system using cable... as long as it doesn't stretch too much, it certainly wouldn't impede axle articulation.
ReBilld
24
Mar 25, 2013 06:32 PM
stephen.south
Jul 13, 2007 10:45 PM
PowerstrokeJunkie
Oct 23, 2006 08:29 PM
countrysF250
Dec 3, 2005 07:15 AM
Franken-Truck
Offroad & 4x4
23
Oct 10, 2005 10:07 PM
